Re: Is Seasonic SS-660KM PSU ErP Ready
I found actually two splitters! They were included with the GTX 970, I just remembered to check its package and I found two of them, so I can now try the SS-400ET.
I found these caps on Farnell:
These are for the smaller caps:
http://uk.farnell.com/panasonic-elec...rad/dp/2217571
http://uk.farnell.com/panasonic-elec...rad/dp/2063079
http://uk.farnell.com/panasonic-elec...rad/dp/2217568
http://uk.farnell.com/panasonic-elec...rad/dp/1907229
These are for the larger NCCs:
http://uk.farnell.com/panasonic-elec...rad/dp/1744878
http://uk.farnell.com/panasonic-elec...rad/dp/1800641
http://uk.farnell.com/panasonic-elec...rad/dp/1800646
Hopefully these could go.
On a side note, I was just reading a topic from about two years ago here on the forum, where a member included links to other posts and problems with the X Series PSUs that are eerily similar to what I am experiencing. My greatest fear is that if I order these caps, disassemble the PSU and tamper with its inners, replace the capacitors and then it turns out that the original Rubycons put in there are not the problem and the PSU continues to exibit the same problem even with replaced caps... it would be a waste of time, money and a futility of taking apart the otherwise very good piece of equipment.
Becasue SeaSonic put high quality caps in there, I mean, we are talking about NCCs and Rubycons here, one cannot guarante that it is not something other than caps. I think momaka mentioned an APFC circuit as a possible culprit for the behaviour. I guess no amount of replaced caps would repair a failing IC. In that case, it would be "cheaper" to simply replace the whole PSU (which is something I'm scared of at the moment given how expensive this PSU was when bought).
