Utilitech LED light strip
  • Welchs101
    • Sep 2008
    • 979
    I have a Utilitech LED light strip go bad. It had some water dropped on it when it was powered up.....anyway, it does not work any longer.
    There is not much to this LED strip light..........i think the problem is in the power supply section...ie...where it takes the incoming 125VAC and conditions it before sending it on to the actual LEDs.
    I have enclosed pics. Now i can throw this away but i thought i would try and fix it for fun........but i am having trouble figuring out identifying the problem.
    Any help would be appreciated.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Utilitech LED light strip
    Well you need to clean that corrosion off the bottom of the Psu first that can cause issues.
    • Welchs101
      • Sep 2008
      • 979
      yes, i have tried to clean off some of the corrosion.........but this would cause a long term ...right.
      • Welchs101
        • Sep 2008
        • 979
        anyone have any thoughts on how to approach figuring out whats not working?
        • Behemot
          • 4845
          • CZ
          These things are usually very simple. The worst problem is if that tiny 6pin SMD controller went bad - I can read what it is, the other question is if it can be found. But I think these PSUs may be bought of ali or fleebay these days.
          Nothing is visually fried there so check the ordinary: fuse, input rectifier, than main switching transistor, capacitors, than move to the SMD diodes and rezistors. If all check fine than most likely it is the PWM controller. These things rarely have any feedback, they are often unregulated (or just by some simple method) so things may blast if something goes wrong.
          I played with one of such, the voltage was 80 V open circuit and dropped to 40-60 under load. Than they just hook all the LEDs in series to that thing. Not the greatest method…LEDs are not incandescent lightbulbs, they do not act properly as resistors. That's why it sometimes blasts…or single LED burns and it stops working.
          ADD// here you can find one for as low as 3 bucks http://www.ebay.com/itm/1pcs-Constan...IAAOSwgQ9VvDeE
          If you won't find the problem quickly just find a replacement which fits, with that price there is no reason to waste time with that.
          • Welchs101
            • Sep 2008
            • 979
            wow.........how on earth did you ever find such a thing on ebay. i actually searched the part number on the board and got no where..............huh, pretty cool you found that. i will check a few things like you said..........its just for fun...........thanks!!!!!!!!!!!!!!!
            • Behemot
              • 4845
              • CZ
              Just search for somethig like T8 LED power supply and check the right one for the lenght and/or number of diodes. I presume they are all just about the same: the number of LEDs is mostly constant and given by lenght (but it may vary so check that), they all have the same voltage drop and they are plugged in groups in series. That means about the same PSU voltage.
              So check how many of the LED groups you have and how many are there in series for each group, but I think it will be similar. The diodes usually require much lower voltage than what's their natural voltage drop (about 3 V) to work effectivelly; at that voltage they produce most light but also too much heat.
              • Welchs101
                • Sep 2008
                • 979
                hi just curious..........first thanks for pointing out that there are "things" to consider when buying a replacement.......like number of LEDs.....what i am not sure of is ......ok lets say i count the number of LEDs in the long strip.........then what.......i could not find where "number of LEDs" was something to consider when ordering a replacement
                • Welchs101
                  • Sep 2008
                  • 979
                  ok, i see after looking closer it says 24 series 4 parallel...........how do i determine this? any ideas?
                  • Behemot
                    • 4845
                    • CZ
                    You can begin by following traces, visually and/or using continuity/diode tester on digital multimeter.
                    • ben7
                      Capaholic
                      • Jan 2011
                      • 4059
                      Interesting board.
                      Did it stop working right when water was spilled on it?
                      If it took a while for it to stop working, my guess would be that one or more of the SMD resistors has corroded. They use a thin layer of metal as the resistive element, which might have corroded away.
                      -Ben
                      Muh-soggy-knee
                      • Behemot
                        • 4845
                        • CZ
                        Shoud not that be inside the resistor package where the water can not reach it??
                        • ben7
                          Capaholic
                          • Jan 2011
                          • 4059
                          One would think so, but I think if the resistors are poorly manufactured, then it might be a possibility. I just read about this failure mode the other day lol
                          -Ben
                          Muh-soggy-knee
                          • edugimeno
                            Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                            by edugimeno
                            Hi There!
                            I'm trying to help my friend who owns a restaurant be just bought.
                            He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                            It's stuck using, I guess, the 2 sided tape that comes with the strip
                            The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                            09-05-2024, 09:34 AM
                            Lithonia Lighting versus Light of America Compact Fluorescent product quality
                            by sam_sam_sam
                            I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                            I also have back when Light of America had these light bulbs available for yard lights
                            The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                            While the Lithonia lighting fixture has all most certain bulb failure
                            So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                            I have only had this light fixture for not more than a year if it...
                            07-02-2023, 03:45 PM
                            LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                            This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-07-2024, 03:40 AM
                            LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
                            This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-06-2024, 09:10 PM
                            09-06-2024, 08:40 PM
