ASUSTech Terminator ATP-1655 PSU
  • Irish_Steve
    • Nov 2015
    • Ireland
    Hi Folks
    Have to try and repair a couple of power supplies that are used on Acer Terminator machines, they are ATP-1655, and the same board is used in ATP-1505 as well
    They are a small form factor Micro ATX PSU that pushes out 165W for the PC, and there's no easy alternative due to the form factor.
    Both power supplies are suffering from bad TEAPO capacitors, one of them has lost the -5V supply, the other was sort of working, but doesn't even start when plugged into my tester box, and it won't power up the PC in less than about 10 attempts, so for now, I've cannibalised a spare machine I have here to get the user out of trouble, but it looks that that PSU is also failing, which doesn't surprise me too much, the 2 I have here have 6 blown 1500uF caps on them, and one also has a bad 220uf as well. The "spare" came from E-Bay, but I suspect that any PSU's from around that time will all suffer from the same problem, so I've got to try and do a repair rather than just throw another second hand PSU at it.
    I can source replacement caps without too much trouble, there are 2 or 3 main line suppliers on line, but I'd like to see if I can get a circuit diagram to try and make sure that I'm not missing anything else that needs to be checked or replaced.
    I have the necessary equipment to do the board repairs, and enough experience to deal with these units, they're not SMT, so relatively easy to work on when compared to some of the later motherboards and the like.
    I need to try and repair them, as the PC they are for is specific, and can't be easily replaced, as one of the software packages on it is tied to the hardware, and can't be easily ported to another machine without a lot of hassle, and the user is planning to retire in a few weeks time, so it's kind of important to keep it going during the transition.
    I've tried the "usual" things like Google searches, and the like, but nothing useful has come to light, and having been a long time lurker here, I decided that a post to see if anyone else has had dealings with these PSU's would be worth a try.
    Thanks in advance
    Steve
  • Behemot
    • 4845
    • CZ
    Re: ASUSTech Terminator ATP-1655 PSU
    Post some pictures.
    It is very rare to find any SMPS diagram these days, it is intelectual property which all manufacturers guard carefully which is understandable - if you made it public, you'd have chinese coounterfeits within a week. You are on your own to diagnose here unless you post some pics.
    • Irish_Steve
      • Nov 2015
      • Ireland
      Rather than fill the server up with similar posts, there's pictures of the PSU on another thread here.
      https://www.badcaps.net/forum/showpo...89&postcount=3
      I won't do better than these without stripping the one here a lot further,
      Picture 3, the 1500 uf caps on the bottom right corner are all blown on both PSU's, and looking at the serial numbers of the PSU's, they came from the same batch of production, so I'm not surprised that both are down. Not sure if I should change the other caps or not, they appear to be OK, so the suspicion is that it's one batch of caps that were bad in this production, and I'm expecting to find the same issue with the third supply that's just about keeping the machine going at the moment.
      • Behemot
        • 4845
        • CZ
        Most of the remaining caps seem to be some Panasonic mixed with something else, can you identify them? Pannies will most likely be OK but the rest may also be good to replace. Other than that, if the problem has been caught on time I don't thing anything else but the caps will be affected.
        • Irish_Steve
          • Nov 2015
          • Ireland
          yes, there's some more teapo caos in there, there's no visible issues, but based on some reading here since my first post, I am with you on getting them out of there.
          The one advantage of having more than one to work with is that in the worst case scenario, I can at least get some comparative voltages between them.
          The one that's not starting on the tester was working in the machine, so I'm reckoning that the only issue is that my tester is not loading the start line correctly, once that's happening, I suspect it will be OK again.
          • Behemot
            • 4845
            • CZ
            Yeah in that case the caps are in bad shape. There is usually high capacity in the computer itself which most likely smoothed it enough to make it run. Just replace the caps and give it a try, you may start with some old HDDs first.
            If the caps are 1500/16 I am out of stock ATM but I will be ordering more Chemi-Cons KYB. Maybe next time.
              ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
              This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
              09-12-2024, 03:28 PM
              HP EliteBook 850 G5 + Mini Dock, Bag & Spare AC Adaptor Notebook 800 Specification for Upgrade or Repair
              This specification for the HP EliteBook 850 G5 + Mini Dock, Bag & Spare AC Adaptor Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 850 G5 + Mini Dock, Bag & Spare AC Adaptor boardview and 850 G5 + Mini Dock, Bag & Spare AC Adaptor schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
              09-06-2024, 08:50 AM
            • CG2
              Janome DC3050 Sewing Machine Pedal Resistance
              by CG2
              OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
              Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
              04-14-2023, 07:53 AM
            • Soulzink
              Samsug washing machine. Power supply DC41-00189a board issue
              by Soulzink
              I am trying to fix a samsung washinmachine power supply main board.
              I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
              Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
              The power supply board reference is the following: DC41-00189a
              I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
              04-19-2025, 06:26 AM
            • unimatrix93
              How to stabilize AC voltage to CNC machine
              by unimatrix93
              Hello there everybody, I'm not sure if it's the right topic to ask this but I hope so.
              I have a CNC machine wired to 3-phase 230V AC.
              It's a smaller CNC machine with a 3500W motor, do it does not uses much power.
              The problem is, when the residents come home and put load on the network, the voltage can drop to around 207V which is fine for most household items but by CNC machine stops working from this.
              I contacted the electricity company but they refuse to help me solve this problem.
              So I started to look around for some DIY...
              03-17-2025, 05:52 AM
