EAX61415301/8 Capacitor value needed!!!
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Hey Guys ,
    Got this power supply from a 42PJ250. Its missing 2 capacitors and i would really like to know the value of those 2 so i can repair this tv.
    Capacitors i need are :
    C502 :
    C364 :
    I know that C502 is 100v.
    Is there anyone who got the same PS and can give me the values? Thanks!!!
  • Khron
    • Sep 2006
    • 1350
    • Finland
    Re: EAX61415301/8 Capacitor value needed!!!
    In photos of this board that i've googled, C364 looks like a 6.3x11mm can. You could try tracing where its legs go, and see what voltage rating the cap "upstream" is. It doesn't really seem to be in a very "critical" location, so i kinda doubt the exact value's terribly important. 47u/50v might be a start?
    Actually, even though it's quite grainy / out-of-focus, i think i can juuuuuuuuust make out 100u/10v, from this view: http://www.bostonrecycling.net/575/l...upply-unit.jpg
    C502 looks to be 100u/100v, in this photo (you can just make out the numbers on the edge of the sleeve) - http://linhkientivi.vn/profiles/linh...8114_pj250.jpg
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
    • Moreno83
      • Jun 2014
      • 2008
      • The Netherlands
      Thanks a lot! I already googled for pictures but the last 1 is what i need!!! Thx a lot! Will give it a try
      • Khron
        • Sep 2006
        • 1350
        • Finland
        I just clicked on "Search tools", and selected Size -> Large, just to increase chances of visibility And then looked for the highest-pixel-count views i could find.
        • MORETTIGIAN
          Capacitor detached from PCB – RTX 2070 Super Founders Edition
          by MORETTIGIAN
          Title:
          Description:
          During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
          I did not notice it detaching, so I am unsure of its original location on the PCB.
          Procedure performed:
          - Removed backplate
          - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
          - Reapplied thermal compound
          - Reassembled card
          Observed behavior after reassembly:
          - GPU powers on and operates normally under...
          09-18-2025, 12:14 PM
        • veedo
          Asus FA507R no power, capacitor needed
          by veedo
          Hello
          I've got an Asus laptop which received with no power, so I found that one capacitor been damaged. I don't have schematics for that board which is DANJMMB11A0 REV:A
          Without that caps laptop is turning on fine so problem more likely is sorted but I would like to put back the correct one as it should be.
          If any way could help with sorting out specification somehow, I just know that my meter shows 11,2uF but is it 50V or 10V ?? or any others.
          See attached photo off the capacitor, maybe someone have same motherboard and can check it for me please.
          03-24-2024, 01:16 PM
        • devsigner
          identify capacitor for MacBook Pro with rare logic board 820-02037-06
          by devsigner
          Hi
          While messing around with my MacBook Pro, I stupidly pinged off a very small surface mounted component that I’m now trying to identify.
          resistance tests show a rising resistance value, indicating a capacitor.
          The laptop boots up and runs, however I'm choosing not to use it until I get it fixed.
          i can’t see any markings on the capacitor at 10x magnification using a professional jewler's loop.
          It seems like there's some damage to the capacitor - one side doesn't have "shiny bits" - can you tell I don't do this for a living!...
          Yesterday, 01:39 PM
        • Prolog
          RTX 3080 FE Identifying capacitor
          by Prolog
          Hi people, I hope this is the correct spot to post this, I'm new to the forum.
          I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
          I hope these photos make it clear which component I am referring to:
          (yes, the soldering is a bit botched from removing the blown one, I know)
          I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
          12-01-2024, 08:27 PM
        • Agent24
          Dick Smith Q-1760 linear power supply filter capacitor question
          by Agent24
          I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
          It has at least one problem.
          The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
          I have already ordered a replacement potentiometer, so that's not an issue.
          Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
          All are CapXon...
          10-21-2025, 05:39 PM
