Tenma 72-10495 (Korad 3005D-2S) excessive current display beyond limit
  • japlytic
    • Oct 2005
    • 2086
    When I was trying to use this power supply as split rails of different voltages, I got a current draw reading of about 6.7A on the left channel (way above its preset limit - both channels can be set up to 5.1A), despite removing the output leads from its banana sockets and earlier on, the left fan was running unusually fast for its settings.
    Carefully grounding the inputs of the TL082 op-amps revealed a drop in the current reading (I suspected the op-amps or the microcontroller was faulty ); an accidental push on the op-amps caused the current display to drop to zero, so the (original) TL082 op-amps on this board along with the op-amps on the other identical channel were reworked and this problem was fixed .
    Note that in Independent Mode, both rails are completely isolated from each other, and in all cases, the communication lines between the microcontrollers on each channel are isolated via optocouplers.
    • 31054
    Re: Tenma 72-10495 (Korad 3005D-2S) excessive current display beyond limit
    so what your saying is the soldering is as bad as the soldering stations!
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      Are the op-amps in a socket?
      I have this Yihua PSU that had the op-amps in sockets!
      WORST OF ALL, the socket contacts were GREEN from corrosion .... failure waiting to happen! I took them out lol.
      Don't want my circuits fried...
      And, that main filter cap which is 50V rated, gets about 55 to 60V on it when the output is set all the way up ... hasn't bulged at all, I think it isn't enough of an over-voltage to cause it to fail.
      Muh-soggy-knee
        • 31054
        ooo - nice avatar!
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          Originally posted by stj
          ooo - nice avatar!
          Hm?, Me?
          Muh-soggy-knee
            • 31054
            yes
            • japlytic
              • Oct 2005
              • 2086
              All of the op-amps are surface mounted.
              • iulik17d
                Intel Arc A380 videocard power limit remove - BIOS needed
                by iulik17d
                Hello everyone!
                The Asrock A380 low profile card (ID 8086 56A5 - 1849 6006) have an power limit of 45W. Intel removed the possibility to increase power using the software utility, anyway the card is in an proxmox machine that doesn't run windows.
                The same hardware is in another form by the name Asrock A380 Challenger that have the same VRMs and the power limit is at 60W. I searched online and found on another website an .bin bios file from the Challenger variant, that I flashed using an CH341a. Flashng worked well, I put the card in PC and booted. GPUz shows that new device ID is 8086...
                01-10-2025, 02:33 PM
              • mariukonie
                i7 2860QM how to raise power limit?
                by mariukonie
                Hi.
                I've just upgraded from i5 2340m TDM 35W to i7 2860QM TDM 45W. All is working fine except during stress test the clock multiplier stays capped at x28 which is 2.8MHz and power draw stays around 35W so it seems the motherboard is limiting power draw. On various websites it reads it should go to 3.3MHz on all 8 cores stressed.
                What is the best way to go about raising power limit.
                a) Bios upgrade/unlock?
                b) Hardware/shunt mod?
                c) Reduce the CPUs voltage somehow?
                Sony Vaio VPCEH2H1E
                BIOS Insyde Version R0200Z9 date 19/04/2012
                Can anyone help with...
                07-07-2025, 12:52 PM
              • chris89
                Which BIOS Editor will Identify the cTDP & thermal limit of AMD A12-9720P & AMD A8-7410 & AMD A4-6210?
                by chris89
                09-10-2024, 09:35 PM
              • Crystaleyes
                Tenma (Farnell-rebranded) 21-10115 solder station question
                by Crystaleyes
                Olá.
                Looking for some help clarifying something.
                I have a Tenma (Farnell-rebranded) 21-10115 solder station which recently burnt out the ceramic element.
                The station is 60W / 28 volts, 110v.
                Right now I'm in Brazil and finding an equivalent element has proved to be not possible, so today I bought a 'Yaxun' 50W 24v iron in the hope that it would work.
                Both irons have a five pin plug.
                The Tenma had pins 1 & 2 and pins 4 & 5 shorted with pin 3 being the ground. No means of measuring the temperature.
                10-19-2021, 08:08 PM
              • CoppellTVRepair
                Troubleshooting PFC with SPC1012T not raising output
                by CoppellTVRepair
                It has been a long while since I posted here to ask anything....hope you can help.
                I have this Samsung power supply that uses SPC1012T as driver for the PFC and it's giving me a problem that I can't narrow down though I've troubleshooted and fixed hundreds of boards similar circuits.
                I am attaching a schematic from a different Samsung board, but the topography is very very similar if not 100% the same and it uses SPC1012T, which BTW is a pinout match to UCC28063 for which there's plenty of information. I haven't confirmed they are functional equivalents, but I strongly...
                03-09-2025, 10:38 PM
