Delta DPS-300JB G Rev 02 300W
  • JEWilson
    • Sep 2007
    • 369
    • Scotland, United Kingdom
    Hi
    These come with the Intel SC5000 chassis. I have of 6 of these.
    Have tested two extra loose PSU (acquired as spares) with PSU tester (for what that's worth).
    The first PSU tester reports no PG.
    The second PSU tester (has an LCD display), similarly so.
    Is this by design?
    I recall the front panel wiring for these chassis (a 9 pin flat ribbon cable) differs from normal ATX.
    Also, as soon as power is applied - the fan will start and
    stay on at a low rpm. To start a SC5000 system, you then have
    to press the front panel power start button - this starts
    the system in full.
    I would like to establish if I have a problem before having to
    pull another (known good and working) out of a server.
    Any advice, help and insight greatly appreciated.
  • 999999999
    • Sep 2006
    • 774
    Re: Delta DPS-300JB G Rev 02 300W
    I have not examined one of those but have a DPS-300BB (FWIW) a while back.
    I would not rely on a PSU tester or at least not alone. At least if you want to use it, determine the amount of load it places on each rail, and what it's threshold is for power-good pass/fail.
    Power good needs to change logical state from
    < 0.4V (off/bad) AND >= 2.4 to (~) 5V (on/good)
    If your tester has a higher threshold than 2.4V, that alone could account for it. Better question is, when the major rails have enough load to keep the PSU running and regulating ok, does the output stay in the required range?
    You write that the fan starts but where is it plugged in? If there's a special proprietary fan connector from the PSU (which does not appear on a DPS-300JB "standard" design datasheet (which Intel could have easily re-spec'd, but I would hope that changed the model name if they did) that could account for it, or simply the board has 5VSB to one fan header.
    To back up a moment, do you have any suspicion they'd failed and that's why you're testing? Normally I would write, attach a larger known load then measure the change in state of the Power good signal comparing AC-connected/off state to full-on state to ensure it flips between < 0.4V and between 2.4 to 5V, BUT a common load I sometimes suggest is a couple of hard drives, which may not be sufficient with this particular PSU unlike some others.
    One notible thing I recall about the DPS-300BB is that it will shut off if there isn't sufficient load on it's 3.3V rail. There were some deals on these a few years back and it seemed like a large % of the brand new PSU were defective but they were simply being tried in nex-gen., non-server systems which didn't put any load on 3.3V rail and so adding a ~ 10 Ohm load resistor to the 3.3V rail did the trick keeping them from triggering the OVP circuit.
    I'm suggesting that if they power on with a load and output voltages measure ok, it's unlikely the Power-Good logic level signal would go bad, more likely a flaw in the way the testers are determining pass/fail.
    • JEWilson
      • Sep 2007
      • 369
      Hi and thanks
      The matter of the PSU fan.
      It does not have any fan leads per se to connect to a mobo header.
      When an IEC plug is inserted to the PSU and that plug is powered
      on at the mains - the PSU fan will spin up at a low rpm. The PSU
      will start the system proper when the momentary switch at the SC5000
      front panel is pressed.
      As I rec'd these particular PSU as spares - I do not know their condition or state and wrongly supposed both of the PSU testers I possess would
      suffice for establishing any immediate problems.
      As I am establishing service records for those PSU I have at my
      place of work, these Deltas amongst a number of others were
      given the once over with the PSU testers and were cleaned
      and physically inspected.
      Of course, this is no equivalent to a full electrical inspection
      as is required by insurance companies and law and is only
      a starting point.
      I will conduct further research on these PSUs and get back to you
      on this
      Regards and thanks for your consideration
        MSI Delta DELTA 15 A5EFK-008 Notebook 15 Specification for Upgrade or Repair
        This specification for the MSI Delta DELTA 15 A5EFK-008 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the DELTA 15 A5EFK-008 boardview and DELTA 15 A5EFK-008 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
        09-07-2024, 03:40 AM
      • Junkrepair
        Calculating ESR from tan delta -- tan delta's dependence on capacitance
        by Junkrepair
        I'm finally recapping my Soyo K7VX6 motherboard (aka KT600 Dragon Ultra) and replacing Sacon SZ-series caps. The Sacon SZ datasheet provides a spec for tan delta, but not for ESR, while the candidate replacement caps are specified in terms of ESR.
        I found this nice little description of the conversion:
        Calculating capacitor ESR from Tan(delta)
        https://forum.digikey.com/t/calculat...-from-tan/2633
        It mentions that a general spec for tan delta has to be adjusted for the specific capacitance before plugging tan delta into the formula...
        06-12-2023, 02:45 PM
        HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
        This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
        09-12-2024, 02:20 PM
        MSI Delta 15 A5EFK-081AU Notebook 15 Specification for Upgrade or Repair
        This specification for the MSI Delta 15 A5EFK-081AU Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15 A5EFK-081AU boardview and 15 A5EFK-081AU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
        09-07-2024, 06:11 AM
        MSI Delta 15 A5EFK-046UK Notebook 15 Specification for Upgrade or Repair
        This specification for the MSI Delta 15 A5EFK-046UK Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15 A5EFK-046UK boardview and 15 A5EFK-046UK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
        09-07-2024, 05:50 AM
