Perma-Power Model A battery-eliminator for antique radios, circa 1949
  • redwire
    • 3910
    I'm repairing a Perma-Power Model A battery-eliminator for antique radios. Circa 1949. 120VAC input; 90VDC 13mA and 1.4VDC 350mA output to replace "A" and "B" batteries. Uses selenium rectifiers. Power for tube filaments has two 1,500uF 3V electrolytic capacitors in a C-L-C pi filter. B+ is a C-R-C filter two 40uF 160V ea. and 1.8k carbon resistor.
    I'm replacing the selenium rectifiers with 1N4005's and 0.01uF RF suppression caps.
    Replacing all four electrolytics, they are a bit leaky after 65 years... and one is only 400uF.
    Adding bleeder resistors.
    Adding a grounded line-cord connected to the chassis. Possible problem as the filament power is chassis-grounded but B+ is floating.
    Adding a primary-side fuse.
    Adding a 91V 5W zener for the B+, if it's too high. Calculations show it will help the 140VDC no-load voltage.
    I'm worried the filament voltage will be too high, going from selenium to silicon rectifiers. Not sure how I will handle that.
    Here's pics to help anyone working on one of these.
    On a sidenote:I9 checked the (label) patent 1789949 and found interesting litigation between Mallory, Aerovox, Cornell-Dubilier, Micamold in some of the history of the electrolytic capacitor. Oddly, Wikipedia says nothing about it and Google does not come up with the litigation.
    http://www.leagle.com/decision/193629415FSupp279_1231
    http://www.leagle.com/decision/193832425FSupp299_1247
    • 31058
    Re: Perma-Power Model A battery-eliminator for antique radios, circa 1949
    forget the 1n diodes and get a small square rectifier with a center hole.
    then you can mount it like the original to keep it looking nice.
    i think the smallest like that are about 4a
    shit - just looked at the schems!
    never mind - use 1n4007's
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      Try a 47ohm resistor to keep the filiment down if its high.
      -valvedubstep on the antique radio forums.
      Follow the white rabbit.
      • japlytic
        • Oct 2005
        • 2086
        Why the HT supply section is isolated is because many battery-valve/tube radios dispense with a C- bias battery and therefore have a resistor between the chassis and the B battery -ve.
        For adjusting the filament supply, you can probably get away with one or more 1N5404 series rectifiers, as standard rectifiers have a near constant forward voltage from zero to maximum current draw.
        • redwire
          • 3910
          Selenium rectifiers I really hate. Selenium->Silicon always results in way too much voltage.
          There is a high and low-tap on the transformer (filament) plug which measure 5.7VAC CT and 6.7VAC CT. My calcs show I will end up with 2.3-1.7VDC instead of 1.4VDC, so I'll drop it with a diode string or a small resistor.
          japlytic you are right about the B+ return not going to ground, it ends up going through an 820R resistor in the radio to make C- for the output tube bias. I will leave it floating.
          When the parts come in, I will update here on what I did to get it to work.
          • redwire
            • 3910
            Just a Follow up:
            I replaced the filter caps with parts from Just Radios. They sell antique radio parts like axial-leaded electrolytics, mica, polystyrene, Orange Dips etc.
            Replaced the selenium rectifiers with 1N4005's and found the B+ and filament voltages too high.
            I added a 91V 5W zener 1N5377B to stop B+ from jumping to 140VDC under no load (until the tubes warm up).
            I added an extra 1N4005 in series with the filament power to get 1.4VDC
            Thanks for the help. Now it's on to the radio chassis...
            • speggio91
              Macbook Pro A2251 820-1949 5V cycling
              by speggio91
              Hello everyone, I've searched the forum but couldn't find a case with the exact same symptoms, so I'd appreciate some advice.
              I'm working on a macbook pro late 2020 with the board 820-1949. The laptop came in with visible liquid damage and corrosion in various areas:
              -speaker amp right side (C6483, C6455) - no shorts detected
              -keyboard backlight area (pin 2 of J8401 was destroyed plus some minor corrosion)
              -C2070 corroded under the pads
              -The most afflicted area is around UB260, RB296, RB29A, RB291, RB263, U3100_R (just a bit on the right side), all the area...
              03-31-2025, 05:14 PM
            • Mark D
              Troubleshooting a Samsung TV: Model UN65JU670DFXZA Version T01
              by Mark D
              I currently (out of necessity) have found myself troubleshooting a Samsung TV: Model UN65JU670DFXZA Version T01. My past has been in repairing antique radios...not new circuits. Here I am very new. The TV would not turn on and did not have a standby light. When I opened the back, I noticed that the power supply board had a blown fuse. While I attempted to search for a short, I found two. Now comes my ignorance...The transistors that I found to be shorted are labeled as: 1E52AH FDPF12N50NZ. The only ones I can find are on Ebay but the top numbers are either 1E16AJ or 1B23BB. Ive never ordered transistors...
              10-16-2024, 05:43 PM
              Motorola DMR radios
              by stj
              anybody know about programming them?
              09-07-2022, 12:03 PM
            • Curious.George
              Antique Vizio tablet looping
              by Curious.George
              A neighbor dropped off an ancient (antique? the thing must way 2 pounds!!)) Visio VTAB1008 for me to look at. After a day on the charger, it's stuck in an endless reboot loop (can't tell it NOT to try to turn on and to, instead, just charge battery!).
              I can divert it to recovery mode which seems like it is stable enough that I could leave the tablet waiting for input for hours without a problem. I've wiped cache and separately restored factory settings (haven't, yet, tried to reinstall an image from a uSD card).
              When charger is disconnected, I just get a momentary...
              01-20-2019, 04:00 PM
            • proton32064
              General Question- Electronics from 70's and 80's
              by proton32064
              I have a question since I am new here and I don't know if this is the right forum to ask these questions or if I am wasting your time.
              I am 67 and have a lot of Radios and Electronics I grew up with which puts a lot of them at 50 years or older.
              A lot of the capacitors are obviously bad but this is my problem.
              An example would be the Panasonic RC-7469 Clock Radio and the Panasonic RF-888 Radio.
              I have others like a Canon L-162 Nixie Desktop Calculator 110AC, etc.
              I have the Service Manuals to some of these and other electronics I have and grew up with and...
              05-09-2025, 05:16 PM
