Excellent power model IT ATX 300w - shuts down after a split second
    master hoarder
    • May 2008
    • 12175
    #61
    Originally posted by kotel studios
    I have found that the diode rectifier was shorted. What's weird is that I desoldered it and the short on PCB and on itself is... gone?
    And since it's an 4 diodes-in-one type rectifier I soldered it back in, checked for shorts in the same spot and powered it on. Was greeted with same results as before... No voltage across primary caps and the bulb stays off.
    Check the fuse and NTC thermistor on the input. If these are good, you have a wiring error somewhere... or user error (multimeter not connected properly or on the wrong setting)... or?? At this point, only you can find out, unless one of us has a chance to teleport and look over your shoulder to see what's happening.
    • kotel studios
      • Dec 2024
      • 193
      • Poland
      #62
      Fuse is good and NTC thermistor is also good (6.8ohms out of circuit). The Y and X safety caps also measure their capacitance, although I don't ready any resistance on them.
      As for the diode rectifier it wasn't ever shorted. I just confused two pins with the ones from the filter transformator (or whatever it is).
      • kotel studios
        • Dec 2024
        • 193
        • Poland
        #63
        The probable cause for no life here was an broken neutral cable going from the switch to the board.
        Although before I go and power it on I must know what specs are the D24 and D16 zener's cause they had no markings and I have replaced them with 4148 signal diodes, which probably could work?
        • kotel studios
          • Dec 2024
          • 193
          • Poland
          #64
          Okay so I have risked seeing the diodes go sparky spark and applied power to the PSU (with the bulb protection). And it's back to the half-dead state....
          I guess we could only drive the primary side with one from another PSU
          Or we could go the screwery way with success chances bellow 50% and put the excellent power parts into the LC board and hope nothing else was screwed, which now it seems there is something badly screwed.....
          On further inspection I see there's only 1.7V on the sec aux rail (at least that's what I think it is cause the other two pins connect to GND and an big diode on the 5VSB).... From the knowledge of the FSP repair I know that two transistor 5VSB PSU's run on 10-14V. Although, the primary BJT's are E13007's and I think they're driving voltage should be 9V or around that....
          Weird how I get nothing when I use the 20V range (2V range shows proper reading, 20V range reads nothing).
          And the "relay" noise I get while shorting PS_ON isn't from the fan, but somewhere from primary/transformator arena.
          • kotel studios
            • Dec 2024
            • 193
            • Poland
            #65
            I have done measurement error. I have accidentally put the probe at 5VSB anode, not sec aux rail cathode....
            I get 16.41V in the correct spot I think that is way too high.... Might be wrong since the all the lythic craps were changed. But nontheless other components might be screwed, but still, above 16V to drive the primary BJT's is too much IMO. I'll try to cut the power to sec aux rail and inject voltages starting from 7V to 9V (emmiter-base max voltage) and if that doesn't help up to 12 or 14v.
            • kotel studios
              • Dec 2024
              • 193
              • Poland
              #66
              So I found something weird out. When I desoldered the anode of the sec aux rail coming from the transformator I now see 1.7V on the rail. I also hear some weird sizzling noise which sometimes appears and a funny smell follows. There wasn't anything shorted.
              Now I am more keen on transferring over the parts from this to the LC PSU board. In fact I might actually start the transfer today.
              As for the destructive test I think it's better to leave as a last resort if the frankenstein excellent power/LC PSU won't work.
              • kotel studios
                • Dec 2024
                • 193
                • Poland
                #67
                Huh, this is weird....
                So I redone the same test again and no wonky stuff. I have upped the voltage to 3v and I only heard the relay sound. And since I didn't have anything left to lose I upped it to 4v and spam-shorted the PS_ON (with the relay sounds). And guess what?
                It works. 5V rail is generating proper (5.04v). Weird how when I turned off the power to the sec aux rail (my bench PSU) the excellent was still running (4v reading from my MM)...
                Anybody that could tell me what the hell is happening here?
                EDIT: I was dumb and I was shorting the PS_ON like it was an PC button
                It now turns on fine when injecting 4 and even 5v. I guess next step is to figure out why the sec aux rail is doing wonky voltage generation.
                • kotel studios
                  • Dec 2024
                  • 193
                  • Poland
                  #68
                  Okay and more weird stuff.
                  Now after putting the sec aux rail diode back in the PSU can start with the original rail? Although there's an weird high pitch sound coming from somewhere primary to transformator side. And it's not the fan (I have unplugged it for funky smell testing).
                  [s]Maybe the BJT's burning? I don't have any more left of them so I don't wanna risk burning my last working pair out....[/s]
                  Turns out it was the 3.3v buck converter coil. Redone the solder on it and the smaller coil near it on the 3.3v rail and the noise is gone and the PSU never died so far from my testing.
                  Can this be that the 3.3v rail had lose solder and was keeping the PSU from starting all along? But I did get 3.3v on the correct pin on the PWM IC before... This doesn't make any sense. sec aux rail is still 16.41v.
                  • kotel studios
                    • Dec 2024
                    • 193
                    • Poland
                    #69
                    Okay it was another 230v cable connecting to the board doing all this wonky stuff. With it replaced the PSU runs stabely enough. No funky smells or anything.
                    Secondary heatsinks get around 54C warm after running with 5 3.5" HDD's and an mainboard without CPU connector in place and an 12v 35W bulb on 5v/12v rails for around 10-20 minutes.
                    I guess this is another repair finalized without the optional compaq PSU which shocked me wit an bright white arc from it.
                    Many thanks to momaka for helping me out here and прямо for sending me an generic 2002/2003 PWM IC PSU schematic.
                    But still, how did the PSU repair itself? It will be another unsolved retro mysteries again....
                    • прямо
                      Viper22A 5VSB circuit
                      by прямо
                      So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
                      In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
                      01-13-2024, 07:05 PM
                    • kotel studios
                      FSP300-60GTF - no 5VSB, PS_ON; 5VSB carnage
                      by kotel studios
                      Finally replaced all of the shorted 4148's and resistors and an blown tl431 on my FSP300-60GTF after 5VSB going crazy and destroying it self. Those components also made the secondary transistors appear shorted (while in reality they weren't).
                      Powered it on through my dim bulb tester and they (bulbs) only flash once meaning primary caps are getting charged, but that's it. No 5VSB, PS_ON voltages.
                      I am sure I have replaced the components correctly and that there weren't any shorted/blown traces left.
                      Any ideas where to go next?
                      02-23-2025, 11:47 AM
                    • huzo
                      HP Omen shuts down when loading OS
                      by huzo
                      The model is 15ec-1061nm
                      Board number is DAG3EDMB8D0​
                      SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
                      10-29-2024, 12:05 AM
                    • Giggle2562
                      Lenovo V15-IIL motherboard swap (in V15-IKB) shuts down when internal display is connected
                      by Giggle2562
                      I have a Lenovo V15-IKB that had a damaged motherboard. I replaced it with a motherboard from a Lenovo V15-IIL.
                      The board powers on, but it shuts down after about 10-15 seconds. This only happens when the internal display (LCD panel) is connected.
                      Here's what I've tried so far:
                      • When the internal display is disconnected, the laptop works perfectly fine via HDMI.
                      • The laptop shows an image on the internal display for a few seconds before it shuts down.
                      • I tried swapping the LCD panel with a known good one.
                      • I tried swapping the LCD cable
                      Today, 12:36 PM
                    • riko 656
                      Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
                      by riko 656
                      I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
                      Laptop Model:
                      • Model: Lenovo Legion Slim 5 16APH8
                      • GPU: NVIDIA GeForce RTX 4070
                      • Main BIOS chip size: 32MB
                      • VBIOS chip size: 16MB
                      Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
                      What I Have Tried So Far:
                      1. I
                      11-04-2025, 05:14 AM
