Dead power adapter
  • kamel
    • May 2011
    • 129
    • TUNISIA
    Dead power adapter
    Hi members,
    Came to me a dead power adapter for repair. Model PA-1400-14 with output 19V-2.1A
    Replaced s/c power fet k3562 with a recovered working one, replaced an open 0R6 source sense resistor, and 2 open smd gate drive resistors. Used a bulb in ac input and plugged adapter. No more s/c, so replaced the shorted fuse and plugged adapter. Led indicator came and 19v also, but led went off under load.
    Every component Checked with ohm-meter ok. Replaced every electrolytic cap. No result.
    Measured PWM IC "marking end is 754M" which seems having same pinout as FAN6754MR : start voltage is oscillating from 20V to 80v. All other pin voltages are also oscillating (Ic vcc, fb as well as gate switching fet drive).
    Any clue.
    Thank you
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    Re: Dead power adapter
    • Dgtech
      E. Technician
      • Apr 2009
      • 1462
      • Steeler
      I can understand the curiosity of fixing this power supply, but they are easily available on ebay for replacing. Like $10. You put more than $10 worth of time and energy into this one. Even if fixed, it may not last as long as simply replacing it.
        • 31246
        "compatable" psu's are junk,
        an original costs $50+
        that's why they are worth fixing.
        yea, cought that bit about the fuse last night!
        • kamel
          • May 2011
          • 129
          • TUNISIA
          Dear colleague, Money is not everything.
          Money goes, knowledge remains.
          • bammbammfran
            • Apr 2014
            • 476
            pictures would be nice
            • jetadm123
              • 2169
              Assuming the K3562 is the switching transistor for the PWM, when it shorted out, it probably damaged the FAN6574.
              • kamel
                • May 2011
                • 129
                • TUNISIA
                Your conclusion is logic. I'm going to replace FAN6754MR tomorrow and see.
                If not fixed will replace the optocoupler as a last resort. Main suspected components being already changed.
                • kamel
                  • May 2011
                  • 129
                  • TUNISIA
                  If not solved after changing FAN6754MR and optocoupler, I'll post a picture.
                  • kamel
                    • May 2011
                    • 129
                    • TUNISIA
                    FAN6754MR is not available over here. Returned the adapter to the customer and unfortunately did not figure out the problem.
                    Thanks for every contributor.
