General troubleshooting flowchart for PSU's
  • fuxxy
    • 318
    Hi guys,
    I'm just getting into repairing PSU's - I know a couple pins need to be jumpered to "turn on" the PSU, and switching PSU's need a load attached to not mess up when powered.
    Is there a general flowchart to determine how the PSU powers itself up? At the very least, some order in which to test in order to determine where to look?
    • 31161
    Re: General troubleshooting flowchart for PSU's
    step1: open it for a visual check - it may save you from smoke/flames!
    (that goes for fixing anything)
    step2 - does the 5v standby work?
    because wihout that - you cant turn it on no matter how many wires you connect together!
    • fuxxy
      • 318
      So that's a good start - Visual check, then +5V standby before anything
      • fuxxy
        • 318
        What happens if I have +5V standby and the PSU doesnt power on when PS_ON is jumpered?
        • everell
          • Jan 2009
          • 1514
          Include in your visual check.............to look at the red switch on the back of the power supply (some power supplies don't have one but most do). I just got a dead power supply from a shop.......the red switch was in the 230 volt position. Here in the United States we run with 115 volts AC. So........of course the power supply would not turn on. This kind of problem can often be solved by simply changing the switch position from 230 volts to 115 volts.
          If you live in a country that runs on 230 volts, a power supply with the switch in the 115 volt position will probably smoke, spark, and create quite a show.
          Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
            • 31161
            it takes out the motherboard - i know someone it happened to.
            • elraymonds
              • May 2014
              About the flowchart, you can check the creately diagramming community for some answers. use an example and start drawing with the flowchart software.
              • blues_spirit
                practical courses for troubleshooting pc motherboards
                by blues_spirit
                Hello from France,
                mon2 kindly advised me to post a thread to ask the question(s) I'm concerned about. I'm new to the forum and I'm looking for practical courses for troubleshooting pc motherboards especially laptops in Europe, if possible in France. I have been a computer network system administrator and a corrector of administration modules for automated programs under Unix. But I really miss the practical "ops" side of troubleshooting. So I would like to start from the beginning: 1.8V, 3.3V, 5V and 19V tests for example, etc...
                Do you think this is feasible for me? I...
                12-18-2022, 12:56 PM
              • AJ847.63e
                Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                by AJ847.63e
                Hi Folks,
                Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                05-06-2025, 10:37 PM
              • Xebozone
                Troubleshooting 2xFailed Cooler Master v650 PSUs
                by Xebozone
                I have a couple of these PSUs that have the exact same issue on both of them. I find it odd that they both exhibit the same Symptoms.
                When plugged into the PC, the PSUs are able to power the LEDs inside the motherboard (the standby 5v circuit I suppose?) But as soon as the power button is hit, the PSU powers on for a split second, then there is a (relay?) click and the PSU shuts off. Hitting power does nothing after unless the power is removed and then turned on again.
                I have a PSU tester which has the same results. As soon as the tester plugs in, it powers on for...
                02-19-2020, 03:27 AM
              • Andre Gilbert
                by Andre Gilbert
                11-20-2024, 08:52 PM
              • acedogblast
                by acedogblast
                11-02-2024, 05:13 PM
