Apple A1407 Power Supply PA-3251-3A2 noise
  • charikabdelali
    • Jun 2023
    • 16
    • Morocco
    I have a problem with an annoying sound coming out of a power panel, a sound coming from a coil, I try to change the capacitors, but there is no change when connecting the computer to the charger, the sound increases and decreases when disconnected
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
    03-31-2024, 02:12 PM
  • televizora
    HP 8470p - distorted sound and noise when playing audio
    by televizora
    Hello.
    I have an issue with HP 8470p - rather strange one.
    I have a noise and sound distortions on both internal speakers and external speakers, when I plug such into the 3.5mm audio jack.
    Seems like the noise is present especially when I play audio, where there are parts/sections where the volume of the actual recorded sound is low.
    Interestingly, when I play the windows sound test, everything seems to be almost okay. The sound/distortions are similar to when you have interference from some other piece of equipment nearby or when you have an audio receiver with bad amplifier...
    12-31-2021, 10:25 AM
  • a_p3rson
    Apple Watch Charging Controller Schematics / Boardview - 820-02601
    by a_p3rson
    Hi there,
    I'm looking for anyone who might have information on Apple's embedded Apple Watch charging daughterboard, ID 820-02601. This is currently used by Anker in their Apple Watch charging products, but likely by other Apple partner brands as well.
    You can see the board referenced in ChargerLab's teardown of the Anker Y1811 3-in-1 MagSafe cube - they discuss the "Apple Watch wireless charging circuit" about 2/3rds down the page. It's not pictured, but the board ID reads 820-02601-A, which sure sounds like Apple.
    This daughterboard uses an interesting...
    04-21-2025, 11:41 PM
  • Biruslapio
    LG 50PB690 power supply terrible noise
    by Biruslapio
    I bought this TV with really bad oxidation on the power supply and bottom X boards, it was working but during pickup there was a lot of background noise so I don't know if it had this problem before.
    As soon as I could I opened the tv and started working on it, did not test it before since it had back bars on the screen and obvious signs of humidity. The X boards were replaced and the screen now works 100%, but the power supply...
    I washed the board and resoldered almost everything on the primary, the oxidation happened because of constant mains AC current flowing,...
    07-13-2022, 12:46 PM
