AGT-1783B SMPS
  • Donny2derby
    • Apr 2023
    • 228
    • Uk
    AGT-1783B SMPS
    Hi all. The above board is for an LED driver which is causing an issue with the lighting panel strobing/flashing. I found 2 caps bulging that actually tested ok but replaced them anyway.
    But now I’m not getting any output at all where I should be getting 48v DC.
    On the primary side of the circuit I have found two resistors in series that are each marked 105 so I’m assuming they are 105 ohm resistors and should be getting around 210 when read through them both.
    However I get 1.92 Meg Ohm. That is with a capacitor removed which is 0.22 uf but actually reading 97.05 nf out of circuit.
    Am I getting somewhere?? Pics of both sides of board attached.
    What is the RV1??
    Thanks.
  • Donny2derby
    • Apr 2023
    • 228
    • Uk
    Ok this is interesting. Incoming fuse blown (F1) and Diode D1 shorted both ways. Is this common??
    • harp
      • Jun 2022
      • 622
      • Planet Earth
      105 resistor marking is 1000000 ohm, 1 mega ohm, in series with same is 2M.
      It is ok, they are in series because to extend gap of high voltage rail (lower voltage drop on each) and serve to discharge capacitor.
      RV1 is varistor, for protection.
      To see diode markings, use razor blade and with flat blade on surface gently scrap coating over it.
      Use angled light, isopropanol, toothpaste and magnificier to see marking.
      Check soldering of these components pads:
      D6, R6, C7, C9, R9, C11, R19, THT leg near R8 marking.
      • Donny2derby
        • Apr 2023
        • 228
        • Uk
        Ahh that's magic mate. Thanks for your help. I've packed up for the night now but will do as you suggest when I'm back in work later.
        Could the two 35 uf 500v caps I found that were blown be as a result of the shorted diode? And would that also explain the blown fuse? Thanks.
        • harp
          • Jun 2022
          • 622
          • Planet Earth
          I dont know whats going on, because initialy you have at least strobe light which mean that fuse was not blown...
          From foto, your desoldering skills are good but soldering are suffer. Use flux, rosin... calafonium... pine resin... and practice, practice practice, the solder joint cant be left in condition like this on caps you replace.
          Generaly, initialy before soldering on pcb, you do some measurements with include major reading like is input, output, rectifier, caps, mosfets... are ok... and write it. Special measurements do on area which you are plan to work. Write down on paper all readings, then begin with soldering work.
          Afret you finish soldering work, you do measurements again, write it on papirus again, and compare results. You do not plug finished pcb simply in mains... it may came to with solder job is somehow do some short, or open, so precaution is always on first place, especialy if you are beginner with lack of experiance. Check, check, check, then test first with bulb current limiter in series...
          https://www.badcaps.net/forum/troubl...urrent-limiter
          • Donny2derby
            • Apr 2023
            • 228
            • Uk
            Thank you for the advice. Yes I know my soldering work needs to improve. That’s why I’m working on these SMPS. They don’t belong to me or have cost me any money so they are perfect for enhancing my solder work.
            • harp
              • Jun 2022
              • 622
              • Planet Earth
              Yes, it is good start...
              I also suggest, regardles to your intro story, to start collecting free ewaste pcb stuff, so to have random free component near you available in stock.
              Also, learn and unerstand how smps work, stages/section, what and how to check, because the most problem is located on power supply board.
              Gather or make basic test&work equipment and learn in depth useing it properly.
              Next learn your prefered stuff, like tv, how they function, sequences, signals, troubleshooting... say
              https://m.youtube.com/@RepairAllTV/videos
              https://m.youtube.com/@tevzTVTevatronics/videos
              • Donny2derby
                • Apr 2023
                • 228
                • Uk
                Thanks Harp. The reason for my questions and trying to work on small PCB is to help me learn how SMPS work. I have found a YouTube channel called Haseeb Electronics very useful. If you know of others I will also use them.
                i should point out I’m an electrician by trade so have a reasonable under standing of diodes/capacitors/inductors etc. However I’m aware electrics and electronics is very different to learn.
                I have certainly learnt a lot from starting. And I'm beginning to understand how to test each component individually. Now I'm hoping to start understanding how they all intergrate.
                I have bought lots of test equipment. Component analyser, a good DMM that tests caps/diodes, LED backlight tester, solder rework station, lots of different components to help me test and fix various problems.
                Very keen to learn and understand more though and help from people like you is very much appreciated!
                • reessi
                  20v / 2A SMPS for a Battery Charger - Explanation of Blown Resistors Please..
                  by reessi
                  My friend asked me to replace the wire going from this SMPS 20v adapter to the charger for a 18v Lithium Battery for a drill.
                  The cable had frayed and been touching, as a result the 5 Paralleled R200 (0.2 ohm) resistors had blown O/C, they are connecting the main -ve rail to the output wire.
                  The output was jumping around 13v and dis-appeared when a load like the charger was connected, they measured 900ohms.
                  I experimented by replacing at first a single 0 ohm and then a 2.2ohm in and the output was restored at 21.62v and 21.65v respectively...
                  08-22-2024, 08:12 AM
                • TinkerTron
                  Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                  by TinkerTron
                  Hey everyone,
                  I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                  Instead, here's what's been bugging me so far:
                  The schematic...
                  03-06-2025, 02:03 PM
                  Acer Predator PH16-71-9705 Notebook Helios 16 Specification for Upgrade or Repair
                  This specification for the Acer Predator PH16-71-9705 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the PH16-71-9705 boardview and PH16-71-9705 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                  09-07-2024, 06:31 AM
                • dkneyle
                  Onkyo DX-V500 Laser Disc Player - weird SMPS fault
                  by dkneyle
                  This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
                  Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
                  02-01-2022, 02:08 AM
                • shamsudeen
                  Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                  by shamsudeen
                  Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                  I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                  i know that in linear power supply the noise will be very low comparing to SMPS supply....
                  07-19-2025, 07:14 AM
