"Can I con?" caps :)
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Found these in a PSU... don't remember what brand or anything.... it was a while ago and I just got around to uploading the pics.
    First I'd seen a Canicon cap. Thought the name was quite fitting
    Ludicrous gibs!
  • gdement
    • Jan 2007
    • 690
    Re: "Can I con?" caps
    Hmm... I've seen some "Cantcon" caps, those things die even on standard Pentium boards. With that lousy attitude of course they don't last. "Canicon" at least has more optimism.
    But maybe I misread them. Might have also been "Canicon".
    • yanz
      • Nov 2004
      • 910
      it was also canicon caps that kill my celeron 300 proc... i also found them on some several cheap psus i recapped..
      days are so short when you actually do something..
      • gdement
        • Jan 2007
        • 690
        When I was learning to replace capacitors, the first board I recapped for practice was a PCChips pentium board on which I had discovered leaking canicons. Before that discovery it gave me plenty of trouble:
        The board was used on my sister's old Cyrix M2 @ 225/75. I had just reinstalled Windows on it and been running it for over a week getting software configured. I finally brought it over to her, and the *first* time we powered it up at her apartment I got the Win2k BSOD. I looked like a jackass. I had to bring it back home and reinstall again, this time I determined 75MHz wasn't stable and ran it at 233/66 instead. Less than 6 months later she had the BSOD again and I moved her to a different system. My testing showed that now even 66FSB was unstable in memtest.
        Sometime later was when I learned about bad capacitors, and sure enough what few caps that board had were leaking Canicons. I don't think many people had that problem on basic pentium level Socket-7. Canicon is that bad - it easily holds the record for failing in the least demanding board I ever had a cap problem with. I think even GSC must be better than Canicon.
          by momaka
          03-12-2025, 03:42 PM
        • eryjus
          by eryjus
          05-10-2023, 11:21 AM
        • Paxman_Swede
          by Paxman_Swede
          Hello!
          01-14-2025, 09:51 AM
        • captain150
          by captain150
          03-16-2025, 07:34 PM
        • Foetuss
          Gigabyte GA-6OXT :: caps question
          by Foetuss
          Good evening
          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
          But I was also suprised about the bigger boys, which are 330µF 25V.
          Could it be they used 25V caps because they were cheaper / available at that time?...
          02-11-2025, 12:22 PM
