Feedback-less SMPS
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Feedback-less SMPS
    I've been staring at two switch mode power supplies that apparently run open loop, at least with respect to the primary side - there's no optoisolator. One is a "6-8 V" that I was using for a cell phone, and this other more recent one is a Lithium Ion standalone battery charger for a digital camera. The first one for the cell phone I guess it's OK if the cell phone itself has a SMPS that's closed loop, but this camera battery charger, not only it runs open loop, appears to have a linear feedback current/voltage limiting (and this is the closed loop section)!
    So I'd imagine and expect the series pass transistor to get somewhat warm... It's a TO-92 SS8050 that "can pass 1.5A".
    How pervasive is this? And I suppose these SMPS can have pitiful efficiency ratings though the devices are very lightweight.
    (Both are MiC but the digital camera charger is Nikon branded - a MH-24... Maybe I have a phony charger? The two electrolytic caps on it look like they're made by Jwco, but I was trying to investigate why it was charging so slowly...)
    [Edit]
    Hmm... Maybe this Nikon charger isn't completely without feedback, there are three windings on the transformer coil and there is a zener on the primary side of it... perhaps it's a winding based primary side feedback solution...
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Feedback-less SMPS
    Ahh I think I got a phony charger... This is not an authentic Nikon charger, no wonder it's so bad...
    • kaboom
      "Oh, Grouchy!"
      • Jan 2011
      • 2507
      No they're not...
      These use the aux voltage (primary side) to determine, via turns ratio, the secondary voltage. Since Np/Ns/Naux is fixed, so would be the voltages between them. This is never the case due to leakage reactance (mostly) and other losses.
      IOW, the feedback point is not the secondary via an opto, but the aux voltage instead. By keeping Vaux the same, the secondary voltage is more-or-less the same. The aux winding has poor coupling/leakage reactance to the secondary, hence voltage regulation is quite poor. 6V+ at no load is rather typical. The "spikes" from Lleak being pumped cause quite a bit of ringing, this can push the output voltage higher still. Say maybe 8V, dropping to 5-6 with a few miliamps. After that ringing-induced voltage subsides, Vout wont drop as much as fast with increasing load. It'll still drop though, again because of Lleak.
      Oh well. At least you know how it works now!
      Connect it to a 10 ohm, 10W resistor and check the voltage.
      "pokemon go... to hell!"
      EOL it...
      All style and no substance.
      guilty,guilty,guilty,guilty!
      guilty of being cheap-made!
      • japlytic
        • Oct 2005
        • 2086
        An example of switching power supplies without a feedback loop can be dimmable electronic halogen/LED lighting transformers, as far as I know.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          Yeah I realized there was a third winding on the transformer and that indeed is feedback. So there is feedback for this phony charger (the other phone charger however only has two windings on the main transformer so it really does not have feedback).
          But this charger still sucks. It uses a series pass transistor (which I don't quite yet understand the topology, looks like emitter follower) and a 1/8W 51 ohm resistor as the current limit(!!!). It has two metal oxide resistors and a TIL431 to do voltage regulation.
          Lots of complaints about this phony charger online, I wonder if I can make this into a better charger. Voltage regulation looks OK, just that it doesn't pass enough current...
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            Hmm... Looks like 9-10V output on secondary regulation, 8.4V output series pass. At 6.4V "dead" li-ion there would be 3.6V drop across resistor and pass transistor... that would mean only 70mA to start charging with. The normal cell capacity is 1Ah thus taking about a day to charge a battery to full! Wow... Awful, Awful. This thing is near useless!
            I wonder if I increase the secondary voltage and reduce the current limit resistor resistance... hmmm...
            • lti
              • May 2011
              • 2548
              Post some pictures of this mess.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                Dang... I finally have cameras that exceed the limits of forum software... heh
                Well, megapixels doesn't mean that much, these were taking by my Canon SD780IS.
                Looks like standard cheap 2-transistor primary with zener + aux loop feedback. Secondary is measured around 10V and there's a series pass regulator - Q4 (front and silk not visible) is the series pass transistor and yes, it is a TO-92 (SS8050).
                The other PSU I don't know if I have a pic of it before trying to mod it, but it is silked for closed loop so I was trying to populate it for closed loop... but haven't finished...
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  Aha!
                  Open loop SMPS (taken by my Canon A60 prior to sensor death):
                  And yes, this SMPS regulation STINKS. Badly.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    Hmm... no, that pinout problem was incorrect. It is correctly E-B-C after all, must have been some side branch - testing in circuit sometimes can be deceiving...
                    • ben7
                      Capaholic
                      • Jan 2011
                      • 4059
                      Wow, what POS's
                      I do know someone who has developed a way to have a primary side feedback, with great output regulation, but he needs to have a few million dollars to design an IC to control it. He needs an IC because the circuit has to be very compact or else it won't work right.
                      Muh-soggy-knee
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        Primary side, as in possible to use a 2-winding transformer?
                        Will the resultant design still be cheaper (with patent royalties) than using an optoisolator?
                        • ben7
                          Capaholic
                          • Jan 2011
                          • 4059
                          It wouldn't require compensation, which can be very tricky to get right, and it wouldn't need optoisolators, which will increase lifetime of the PSU.
                          Muh-soggy-knee
                          • motormayhem
                            Lenovo T460 Only Charges on One Charger
                            by motormayhem
                            Laptop Question
                            I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                            A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                            05-12-2023, 01:46 PM
                          • CiorapulUcigas
                            OLED65CX5LB PSU Feedback Loop Issues
                            by CiorapulUcigas
                            Hey guys. I have the dreaded OLED65CX5LB that LG decided to make REV 2.0 of the PSU 5 months after the first rev. If they moved that quickly you know that there is a problem ha ha.
                            My TV still has REV1.0 and has died. I have managed to get it back to life and it is working almost faultless.
                            The TV turns on if I press the power button 4-5 times. Once it's on it works perfectly and no reset clicking can be heard.
                            While on Stand-by I can hear the resets clicking, so I decided to investigate.
                            Well I am a bit stuck and need some help
                            The IC that controls...
                            07-13-2024, 04:16 PM
                            NVDC charger configuration...
                            11-05-2024, 03:28 PM
                          • flat-earther
                            how to prevent a connected charger from draining battery when not charging?
                            by flat-earther
                            I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                            So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                            but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                            So the battery is backfeeding the charger and being drained.
                            How can I prevent...
                            08-07-2025, 01:04 PM
                          • Takeatry
                            Yet another Samsung QLED Boot Loop
                            by Takeatry
                            Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                            10-04-2024, 02:57 PM
