Modify output voltage of a Dell power brick
    Re: Modify output voltage of a Dell power brick
    The output voltage was probably too low. Try turning the voltage up. If this is the case you will need to modify the main transformer and increase the turns on the auxillary winding for the Vcc for the controller.
    • RCKadath
      • Jun 2013
      • 16
      Thanks for the suggestion Tom but the output voltage was set for 17V (nominal was 19.5V). I can't go higher because 17V is the max my charger will support. I nvereless tried to increase the voltage but it doesn't help. Looks like I broke it somehow.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        Originally posted by tom66
        I think that decreasing the 69.8k resistor will decrease the output voltage.
        That is a bad idea. Do not modify the top resistor of the feedback divider in ANY SMPS unless you have a good reason to do so. If you need to change the output voltage, adjust the lower resistor only. The reason is that the top resistor plays an important role in the feedback loop, and altering it will, most of the time, lead to oscillations and related nasties.
        A working TV? How boring!
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          Agreed, learned that the hard way before. It can even cause the PSU to appear to not work at all.
          Muh-soggy-knee
          • RCKadath
            • Jun 2013
            • 16
            Thanks for the warning guys. In my case I modified the lower resistor.
            I have another 65W Dell brick that I'll try the modification on. Hopefully I won't destroy that 2nd one. I kinda lost motivation however...
            • electron_jj
              Panasonic TH-L42D25A checking the PSU output voltage
              by electron_jj
              Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
              I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
              08-29-2021, 08:13 AM
            • Vampy_1110
              Modifying output voltage of an Old Dell laptop charger
              by Vampy_1110
              I'm trying to turn this old dell laptop psu into a variable power supply (5-19.5) as i have already modified a few power supplies before and now i want to do the same with this but it's a bit complicated
              The pic below has an op-amp ic (Z103WA) that does the CC/CV adjustments and a double diode 3 pin ic at the far right
              As you can see there's no TL431 or Switching ic self-regulations that i can tweak easily.
              Any help would be appreciated
              02-12-2024, 03:17 PM
            • sergiosergio
              Dell DPS 1200MB-1A increase voltage output
              by sergiosergio
              Hello everyone!
              I have this power source and I turned it ON connecting the pins with an Ohm resistor. The output is about 12V and I need to overcome the voltage protection and obtain between 13.8V and 14V.
              If someone could tell me how it can be done I would really appreciate.
              Thank you in advance!
              I am attaching pictures of PSU....
              11-12-2022, 09:59 AM
              How to modify a switching power supply that has voltage/current adjustable but powering it from a battery pack
              by sam_sam_sam
              I have been pondering this question for a while but now I have see if this doable but I need to answer this question once and for all
              I would like to know how to safely do this undertaking my first thought is to solder wires to the main filtering capacitors and see
              what voltage I am getting and seeing if I can build a battery pack with voltage or not and if
              I can find a BMS balancing protection board at this voltage level and weather or not do I have use more than one BMS balancing protection board...
              05-11-2025, 05:22 PM
            • David Miteff
              NM-D521 rev. 2.0 output voltage on CPU coils seemingly low
              by David Miteff
              Hello, guys!
              As the title says - the board is NM-D521, on the input of the CPU coils I read 1.2-1.3V, which should be normal, but on the output I read around 0.6-0.8V. The laptop bootloops with no picture.
              As of right now I don't have a thermal camera, so I can't confirm a shorted or partially shorted CPU chip. Do you have any other suggestions as of why the output voltage might drop like that?...
              12-30-2024, 07:02 AM
