AC power switch
  • Behemot
    • 4845
    • CZ
    AC power switch
    As the Huntkey FX500SE lacks power switch, it brought me to question, is that demanded in any european norm, or is that completely optional?
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • Powderfanupnorf
    Dell AL440LX power on switch circuit help required
    by Powderfanupnorf
    Hi Everyone. First official post so fingers crossed I conform and also manage to get photos to work.
    So I am requesting some help from anyone who happens to have one of these motherboards to hand and perhaps a multimeter.
    My board has a single row of header pins for all the front panel stuff (have seen others where they are grouped together differently so thats no help) and the two pins for the power on switch had been previously repaired and I am trying to make a better repair. There looks to be pad and trace damage and im happy to relocate the header pin/pins to...
    06-24-2024, 01:24 PM
  • grimacelord
    NEC TurboExpress On/Off Power Switch Replacement Help
    by grimacelord
    I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
    I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
    I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
    11-09-2023, 09:49 AM
    09-06-2024, 05:59 AM
  • shovenose
    Ubiquiti Unifi PoE Switch US-8-150W Power Supply Failure
    by shovenose
    Got this one for free because, well, it no worky.
    A little research and there are tons of complaints all over forums/the internet about premature failure of these switches. The observation everyone makes about these is "they run hot" and failure occurring as soon as 13 months, right out of warranty, of course.
    Upon removal of the cover I found a G0398-15011480A power supply that, when plugged in, was making a constant ticking noise. Multimeter confirmed the PSU was the issue. Output was cycling between 0 and about 20V. With output disconnected it sat around...
    08-11-2021, 01:26 PM
