HP laptop P.S. stuffed with silicon? NO PROB!
  • ben7
    replied
    Re: HP laptop P.S. stuffed with silicon? NO PROB!
    Originally posted by glutton4punishment
    Thanks Ben!!!!!!!!
    I cut off 2.5" from the cable where it meets the P.S. board, soldered it back to the board, and I'm back in the saddle again!
    So the short was around the area of the strain relief on the adapter? That is a common spot for failures in these cables.
  • glutton4punishment
    replied
    Originally posted by ben7
    The cord has a short inside it. You will have to get a new one. Or get the type of connector that goes into the laptop, and attach a new cord onto it yourself.
    Thanks Ben!!!!!!!!
  • ben7
    replied
    well there's a big diff from before, but I don't know what it means!
    On the cap I measured before,(i.e., the one Bud told me to measure) it's 0.85 M ohms, and immediately slowly decreases in value. With the cord attached, it was 1.8 to 0.6 ohms, not M ohms.
    On it's twin cap (the other output) it's 0.69 M ohms, and immediately slowly decreases in value.
    Now what??
    Do this with the cord desoldered:
    Put your meter on dc volts, and plug the charger in. Test the voltage across that capacitor. You should see a voltage there, and the ticking sound will be gone too.
    replied
    Desolder the cord that goes to the laptop, taking note of which wire goes where on the pcb. Then, measure the resistance of those two points again. If there is no short, then the cord is bad.
    Now what??
  • ben7
    replied
    with a DVM, it starts at 1.8 ohms, within a second drops to 0.6 ohm, and is steady there.
    thanks for the help!
    replied
    So yeah, let's try this again.
    Please measure the resistance across the two points budm marked in that picture. The power supply doesn't need to be plugged into the wall.
  • ben7
    replied
    replied
    Originally posted by budm
    post 18
    "What DC resistance do you get measured right at two legs of either one of the output filter caps sitting at the edge of the board?" I post the picture with redlined to where to check the resistance, that is the output section,
    Sorry, I don't have a big screen, and I didn't see any markings on the pic you quoted
    I should be more clear about the power supply should not be connected when you do any resistance reading, but I assume the common sense to kick in for the tester know what to do when check the resistance in the circuit.
    "It seemed to me that a teenager was trying to get me to short out the 400v cap to get me to either electrocute myself or get me to pull off a big bang and spark to scare the hell out of me." How did you assume that? I do not know where I indicate to short out the 400V cap!
    All we are trying for you to do is to find out if you have shorted circuits in the secondary side but sure having a hard time with it.
    I am out of here.
    I already apologized. Thanks for your help/
    replied
    post 18
    "What DC resistance do you get measured right at two legs of either one of the output filter caps sitting at the edge of the board?" I post the picture with redlined to where to check the resistance, that is the output section, I should be more clear about the power supply should not be connected when you do any resistance reading, but I assume the common sense to kick in for the tester know what to do when check the resistance in the circuit.
    I am out of here.
  • kc8adu
    replied
    output=low voltage side.you likely have a short on the secondary(output)side.
    rest assured that anyone suggesting you do something potentially deadly will get said post removed and a vacation!
    replied
    If I misunderstood your intent, I apologize, and will remove my post.
    If there was no bad intent, I'm sorry, but at the end of the day, I didn't understand what you wanted. I thought if I tried to measure the DC resistance, with or without current, I'd either get the spark/bang or fry my meter.
  • kc8adu
    replied
    Wtf!
    what reaction do you get when you swallow a 1/4 cup of granulated draino?
    replied
    A lot of power supply will put Zener diode for crow bar protection right at the output which will be in parallel with the filter caps, the Zener voltage will be 2~3V higher than the output voltage, it will crowbar the output and shorted itself out.
    So far the symptom looks like the powers supply is trying to drive the shorted circuit (as other also had indicated) in the secondary side, unless it is the start up cap problem in the primary side (but with bad start up cap usually you will see some DC voltage pulses on the output filter caps).
    replied
    what reaction do you get when you swallow a 1/4 cup of granulated Draino?
    replied
    replied
    Originally posted by mockingbird
    The small one near the two large ones, and the two medium size blue ones on the left side. They say "Ltec" on them in cursive.
    OK, I replaced the 3 caps. That wasn't the problem b/c I'm still getting no voltage at the output, and it's still making the beeping noise.
    replied
    Unplug the the power to the brick, then check the resistance reading on the pins (+/-) of the DC jack of the brick to see if it shows really Ohm reading.
    First I checked resistance of the P.S. cable from the 3 wires of the board on one end until the end of the P.S. cable that plugs in to the laptop. There are two black wires and one white wire on the board that lead into the cable that goes to the laptop. One white and one black wire show continuity from their respective connection points on the board to the outer metal jacket of the P.S. cable. One black wire shows connectivity between the connection point on the board to the inner pin of the P.S. cable
    Resistance between the inner pin and the metal jacket that plug into the laptop shows infinite .
    replied
    replied
    Originally posted by kc8adu
    the dc plug is shorted on that unit.very common.desolder the cord from the board and it will work if you have not damaged it.
    I wish!! after I checked the voltage at the computer plug side, I checked the voltage at the pins at the P.S.
    Zero voltage.
  • kc8adu
    replied
    Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
    This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
    09-06-2024, 09:30 PM
    Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
    This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
    09-06-2024, 08:47 AM
  • RdeveLabs
    MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
    by RdeveLabs
    To all the members here...
    Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
    So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
    05-05-2025, 04:59 AM
    Microsoft Surface Laptop Surface Laptop 4 Notebook 4 Specification for Upgrade or Repair
    This specification for the Microsoft Surface Laptop Surface Laptop 4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 4 boardview and Surface Laptop 4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
    09-07-2024, 06:11 AM
