Re: Infocus power supply isssue
A little update I got a Viewsonic projector that is a clone of the Infocus so they had the same power supply and mainboard, my projector starts up fine now.. I was STILL unable to find out why the other board still does not have power :-/
I checked the old with the new and the readings matched up :-/
Getting 0V from IC101 (PFC IC) checking with the ohm meter the VCC pin of the PFC seems to be connected to C117A, C117, C116 which seem to be connected to the FSU10A60 The output pin on the PFC seems to connect to the same SMD caps but connects to D107, Q602 & Q603
Check for the DC Voltage of the VCC pin of the PFC IC and its Ground pin. I do not recall the IC of number of this PFC IC, it has been a long thread.Leave a comment:
So I should be looking between the main and the PFC for something shorted or open circuit then? I was looking at D103 on the back of the board I think it's just reading both ways because it's in circuit, and for ZD204 it appears they are only using just one of the zeners.
I'm checking with a analog ohm meter
but yeah I suspect I was not going to see that voltage on the connector, One thing I might of been doing wrong as when checking for voltage on the PFC I should of been checking between VCC and the filter cap?Leave a comment:
If the PFC Voltage booster is not working, the DC voltage on that main DC filter cap will only be = line voltage x 1.414, you will not have 339V without PFC working.
https://cdn.badcaps-static.com/pdfs/...f33e6f6571.pdfLast edited by budm; 08-18-2013, 07:35 PM.Leave a comment:
Not mine but from a similar projector
I was told that regardless if the PFC controller was non fuctional I should still have like 339 VDC if not I must have a open circuit between the mains input and electrolytic filter capacitor, assuming the filter caps for the main?Leave a comment:
I was searching online today and I noticed the Acer X1220H has the same case design as my Infocus.. does this mean it uses the same power supply?
X1320WH is more closer to my infocus and from what I can see here
add the ViewSonic PJD5523w to the list of projectors as well.Last edited by subarub4; 08-14-2013, 09:43 PM.Leave a comment:
I thought about something I'm not sure what came before the In116 model projector (what I have) but I was thinking of getting a power supply close to the model since the connectors seem to be about the same.. whatever that does not fit I can swap over.
I figure it will turn on without any issues, too little current or too much voltage.
Since I know the standby should be around 5V and turn on would be 12V for the output I can go about that.
Tried of looking at the projector case in my closet and my color wheel and DLP chip in my wine cabinet.Leave a comment:
It blew the fuse? Did you check those leftmost pins in the picture to see if they were shorted together (they look bent/contacting eachother in your picture). Also the 3rd and 4th pins (from the left) look like they are shorting together too, in your picture.Last edited by ben7; 05-29-2013, 09:58 AM.Leave a comment:
And it did what I knew what was going to happen, a dead short because the pins are now reversed.Leave a comment:
The replacement "only" had its pins bent in different directions compared to the original, that's all. The order (and function) of the pins should be the same. By "different directions" i mean front-to-back, *NOT* side-to-side.
Quick comparison (original vs replacement):
Pin 1 - straight vs. bent backwards
Pin 2 - bent forwards, both
Pin 3 - straight vs. bent backwards
Pin 4 - bent forwards, both
Pin 5 - straight vs. bent backwards(?)
Pin 6 - cut
Pin 7 - bent forwards vs. bent backwards
Pin 8 - cut
Pin 9 - straight vs. bent forwards
Not sure if you've noticed, but these multi-pin SIP (Single In-line Package) solutions, where the pins are bent, they're bent *ONLY* along the forward-backward plane, and *NEVER* from side to side. What you did was simply reverse where pins 7 and 9 go in the circuit, and, well...
Quite likely, 1) you toasted the new MR4010, and 2) less likely, caused further damage in the primary "half" of the power supply.
"Assumption is the mother of all f**k-ups" - you'll have to excuse the harsh language, but i've seen that adage proven true time and time again
Edit:
The original doesn't seem to have its legs crossed, as opposed to the new one: https://www.badcaps.net/forum/attach...7&d=1369707694
btw I had the same voltages as I did before with the original.Leave a comment:
Pin 6 - cut
Pin 8 - cut
Edit:
The original doesn't seem to have its legs crossed, as opposed to the new one: https://www.badcaps.net/forum/attach...7&d=1369707694Last edited by Khron; 05-28-2013, 08:50 AM.Leave a comment:
The pins are not twisted it's just how it is, I did not bend the pins in the same way the original was.
And for the info it still gets as hot as the original did.
And if you saw I blew the fuse because I used my oscilloscope on the MAIN input, had I used a isolation transformer I would had no had the issue, if you think it's not true wait until my replacement fuse comes in.Last edited by subarub4; 05-28-2013, 08:20 AM.Leave a comment:
No wonder why it is getting very hot! xDLeave a comment:
Ummmm... Why are the last two legs of the MR4010 "twisted" like that, pray tell?
Did the original one look like that, as well?
Edit: Nnnnnnope...
https://www.badcaps.net/forum/attach...0&d=1368496802
What you did there, was (most likely) reverse the Source and Drain pins of the FET inside the MR4010 (so basically you're putting the +160Vdc through the Source-Drain parasitic diode, straight to ground). No wonder you blew the fuse...
Edit 2: Correction - you reversed the Drain with the Vin pin, so you shoved +160v DC into the low-voltage section of the PWM chip. Pins are numbered for a reason, y'know...Last edited by Khron; 05-28-2013, 04:23 AM.Leave a comment:
underside looks a little rough with all the flux..Leave a comment:
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by JimBanvilleThe sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
Opened it up and discovered the power supply is making a faint clicking or ticking sound.
I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...-
by CMCMHello Everybody,
Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
The outputs marked 12v and 20v are all measuring only 1v.
The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
The capacitors physically look clean (no bludgesor leaks) and... - Loading...
