Snubber failure in Sparkle auxiliary flyback circuit
  • linuxguru
    • Apr 2005
    • 1564
    I encountered an unusual failure in a Fortron/Sparkle FSP280-60 PSU for a 2U Pentium-III class machine. The secondary caps were a mix of Fuhjyyu and Teapo, were OK, but I recapped them anyway as a matter of routine.
    However, the auxiliary flyback converter had a failure - the switching device (a Fairchild 1H0165R integrated SenseFET/current-mode controller) and its snubber network (back-to-back FR106 and a PSK 180v Transient Voltage Supressor from Taiwan Semiconductor) had all shorted.
    A quick analysis (from circuit topology alone) reveals that even if a switch breakdown occurs and it shorts drain to source, there's no way the snubber network should breakdown and short. Therefore, the failure initially
    must have happened in the snubber, either in the FR106 fast-recovery rectifier or the 180v TVS, shorted each of them progressively, and then the SenseFET switch failed, followed finally by the fuse.
    Has anybody else seen snubber-network failures of this kind?
  • Super Nade
    • Jun 2006
    • 294
    Re: Snubber failure in Sparkle auxiliary flyback circuit
    Any clues from the derating curve of the device? How old is it?
    Q6700 @ 3.6 GHz
    Zippy GSM-6600P
    Curcial Ballistix PC6400 (4 x 1Gb) Micron D9GMH
    Abit IP35Pro
    ATi HD4870
    • tony359
      Faulty CRT AKF12/Philips CM8500: bad flyback?
      by tony359
      I have a CRT (Acorn AKF12, based on the 240V version of the Philips CM8500) which has stopped working. It's making a high pitched noise but not too high. I know this is symptom of a faulty flyback.
      What happens when a flyback fails? I see that the main voltages out of the PSU are not reaching rated values, as if there is a short.
      There are supposed to be 125V/26.5V/15.5V outputs but I am reading something like 48V, 10V and 8V. If I unplug the PSU from the rest of the PCB, I can measure the expected values.
      Can it be a short somewhere...
      08-22-2023, 04:39 PM
    • Sus256
      HISENSE 65E7KQ PRO - no boot
      by Sus256
      Hi all!
      HISENSE 65E7KQ PRO
      RSAG7.820.13512 - chassis
      MT9618BAATAB - cpu
      RSAG7.820.12059 - power
      HD650Y3U77 - panel
      KLM8G1GETF - emmc
      Replaced emmc.
      Terminal log
      UART
      AC_ON
      E-B
      FDE enabled
      06-01-2025, 02:11 AM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • ctroxtell
      Carrier HK50AA063 display controller common failure help
      by ctroxtell
      I've got a control display for a Carrier chiller that I'm trying to understand what the common failure with these boards are. This is the board in question https://www.supplyhouse.com/Carrier-...arquee-Display all of them seem to develop a failure with the up and down arrow buttons on the right side of the display, the esc and enter keys I've never seen fail. Once these boards are plugged in they run 24/7, you used to have to press extremely hard with the end of the blunt screwdriver and you could still get the arrows to work but now it has completely stopped working. The button...
      02-05-2025, 05:31 PM
    • howardc64
      Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
      by howardc64
      Problem
      Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
      Model & Board Pics
      Conflicting Spec
      Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
      https://www.shopjimmy.com/vizio-gj-2k1...
      10-10-2024, 01:16 PM
