Hi to all.
For ATX power supplies, Hobby shelter I have a dozen currently being repaired.
Among those in repair I have a Mini-ATX Bestec Model ATX-1523F 150W Max, I'd like to fix.
The power supply does not start, I note that tensions are low + 5VSB (Purple), 28V, +1 and PS-ON (Green) +1, 12V.
Within any swollen capacitor.
To create space I disassembled the double fin secondary diodes, which I checked to be good.
List them: CTX12S D13, D14, D12 F10P10Q CTB34.
Primary capacitors are n° 2 330μF 250V CapXon. In the secondary have no. 3 VENT 680μF 16V, Jamicon 2200μF 6 n° 4 and n° 2 10V-16V.
The other two are small hidden next to primary, one is a 220μF Jamicon 25V, but I can't read what it is the other smaller.
On a welded on the main card, there are other small capacitors, Jamicon, about 8, those are readable from 0.1-0.22-2.2 μF 50V.
In the back of the main Board (circuit side) there's some SMD, while the back of the secondary card is full of SMD.
It is evident that the auxiliary power supply voltages are too low.
According to you, the only replacement of auxiliary power supply capacitors, could solve the problem?
If someone would kindly advise me what or where to look.
Thanks A Lot
Thanks A Lot
(+ and-
