Fenton BS-1700 UPS - bad AC input relay X-cap
  • japlytic
    • Oct 2005
    • 2086
    On a Fenton BS-1700 UPS, it has the problem of not always starting up (often, with a relay chattering) when AC is applied to the mains input.
    So I tried checking the X-class series capacitor (which acts as a reactive component for current limiting for the AC input relay which closes when AC is applied to the mains input - it is not controlled by any other circuitry) and upon measuring, it was less than half of its rated 0.33uF capacity, and replacing this component fixed this problem.
    The X-class capacitor at fault was a Carli unit - I've seen X-class capacitors lose significant capacitance in some cases over time during use.
    A good tip from me is to check any X-class capacitors which are being used as current limiting capacitors as I mentioned earlier.
  • CoinCoin88
    Garage door RX unit (Cardin S38C) does not short relay to send opening signal
    by CoinCoin88
    I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
    Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
    09-15-2025, 03:36 AM
  • ugamazing
    820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
    by ugamazing
    So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
    1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
    2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
    04-10-2024, 08:06 AM
  • valvashon
    Repair Success! Middle Atlantic UPS2200R-IP
    by valvashon
    Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
    Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
    02-06-2024, 12:54 PM
    Texas Instruments bq24745 bq24745RHDR bq24745RHDT Battery Charger IC for Laptop Computers Datasheet
    The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
    The bq24745 features dynamic power management...
    10-23-2024, 02:50 AM
  • edugimeno
    Biomass Boiler not driving cleaner motor relay. ENERTRES BIOMASA BI-650
    by edugimeno
    Hi everyone!
    I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
    I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
    This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
    To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
    I respected the polarity, positive to cathode of protecting diode
    So provided all...
    04-18-2024, 01:15 PM
