Samsung LED TV UE40C5100QWXXU fuses blown
  • dynomo
    • Oct 2012
    • 6
    • uk
    Samsung UE40C5100QWXXU led tv. PSU BN44-00353A.
    Both fuses on the mains input open circuit. T6.3AH ceramic fuses. No shorts found in circuit at all? Rectifier tested fine. Any idea's?
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Samsung LED TV UE40C5100QWXXU fuses blown
    Could be a secondary side short, although mostly that will cause the switching transistors to explode.
    The switching transistors could be open circuit too. Not only the switching transistors could be broken though! The current sense resistor(s), diodes, even transformer windings!
    Pictures?
    Muh-soggy-knee
      A secondary short will not cause a primary failure on a well designed PSU.
      The switching transistor, PFC transistor, or the controller ICs could be at fault here.
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        Ok, correction accepted
        Muh-soggy-knee
        • dynomo
          • Oct 2012
          • 6
          • uk
          I have found the problem. Found 8.5k ohms across bridge rectifier + - After some investigation found CP818 / 100pf at 1KV burnt on the side
            09-07-2024, 05:50 AM
          • cheeky2
            Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
            by cheeky2
            This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
            I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
            Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
            06-15-2025, 05:12 AM
          • MrzPdlch
            Blown fuses on Gigabyte GTX 980TI 6GB
            by MrzPdlch
            Hey everyone,
            I just went ahead and unscrewed a faulty GTX 980 TI from Gigabyte. What I found beneath the cooler was, as it seems, a common issue of that card. Two blown fuses on the bottom right corner of the card next to a MOSFET.
            Now my question would be if there is any schematics of that card available to figure out which are the blown components so I can try and replace them together with the mosfet if needed.
            Find some pictures of the actual GPU together with a picture of how it should look like.
            I also wonder whther it might be a problem that there...
            03-10-2024, 04:14 PM
            09-06-2024, 11:40 PM
