2009-2011 Apple iMac 205W Power Supply Pinout?
  • JuniperSprouts
    Solder Soldier
    • Aug 2010
    • 119
    I will offer a small reward for this.
  • keevo24
    • Costa Rica
    Re: 2009-2011 Apple iMac 205W Power Supply Pinout?
    HI all . I have a Imac 24" The guy who gave it to me didn't have it protected by anything, and it got hit by voltage spike. After taking apart, I realized the Fuze was blow, I replaced. It blew again. Its hard for me to find a Power suply local to test if anything else is bad. So I grabbed a PSU from a old G5 MDD tower that was int perfect working order. I am making a adapter to run the unit.
    The problem is all the cables are BLACK!!!!!! what a dumb idea. I mean they have to make it look nice on the outside, but really. whats the point???
    So far I have found the following pinout.
    1,3,7,8,14 Ground
    10,11,12,13 12v Because 1 of the pins goes to the Inverter board for the Display and it says 12v inout 63v output
    2, unkown, but its a Small thin cable going to Mobo, and the Trace on the PSU goes back to and unkown area on top of PSU passing the vari-sistor
    4, Has a heavy duty trace going to the Center Post of 2x paralleled T03P (Note: it seems the output of the T03P goes to Power 10,11,12,13 pins)
    5, Goes to a trace on the PSU that seems to switch on the two T03P Mosfet after hitting a tiny transistor.
    6, Goes to same area but after several mini Filters and Resistors it returns to the input of the mosfets,
    7, Ground leads back to the area of 5 and 6,
    any help to get the power on the MOBO so i can test the rest of the unit would be greatly appreciated.
    Kevin
    • Toasty
      • Jul 2007
      • 4171
      Is that the square, open frame one with the corner chopped off where the connector is? Is there an Apple PN on it?
      T
      veritas odium parit
