Slim Desk Top Power Supply Very Bad Caps
    • Jul 2011
    • 6059
    My boss brought his computer to work and said it DEAD would not power ON
    after power outage that lasted two hour
    Took a look at the mother board and most of the caps that are 850uf and 1500uf @ 6.3 volt had pop there tops a total of ten caps
    So I thought let me look at the caps in the power supply and all of the caps that are 100uf and less to 4.7 uf where all open no ESR reading
    about 10 of them
    This is the first switch power supply that I have seen that all of the low value are open like that
    I replaced all of the caps and the main power caps as well and all of the pop caps in the power supply
    And it came back to life I ran for about 30 minutes 2 different time and it seem to work OK
    I am going to recap all of the caps on the mother board
    Do you think there is any thing I should look for after I recap all of caps
    when doing a burn in test
    • Jul 2011
    • 6059
    Re: Slim Desk Top Power Supply Very Bad Caps
    Up-Date.........> Burn in Test
    I fix this computer and save it from the land fill
    I also replaced the power supply fan
    This was bad would not run this was the cause of all of low uf value caps to be open they where all COOKED to death
    The brand of these caps I have not seen before the system fan for the CPU chip
    This computer was left ON from about 5 pm yesterday to 6 am today and was still working
    I ran a virus program that was on this computer and while I was running it the
    CPU system fan speed up and slow down and every thing seem to work the way it should
    • OniJon
      Computer Expert
      • Jun 2012
      • 82
      • Finland
      Very good!
      I'd like to repair stuff like that too, but here in Finland everybody's just "ahh, it's scrap, throw it out"
        • Jul 2011
        • 6059
        Originally posted by OniJon
        Very good!
        Here in the USA there are alot of people that feel the same way
        • OniJon
          Computer Expert
          • Jun 2012
          • 82
          • Finland
          Yea, it's stupid. You can have the good old machine back for less money and hazzle than buying a new shitty one.
          • Khron
            • Sep 2006
            • 1350
            • Finland
            Very good!
            Too true.....
            And not fair!
            Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
              03-31-2024, 02:12 PM
            • eryjus
              by eryjus
              05-10-2023, 11:21 AM
            • captain150
              by captain150
              03-16-2025, 07:34 PM
              07-01-2024, 06:34 AM
