For their customers' sake, I hope Corsair is acquiring genuine NCC capacitors.
They usually used LTEC on the secondary side (which are about on par with CapXon in terms of quality from my experience).
Hard to say. I say that because if you read this thread, in a DPS-800GB, it didn't take long for a KZH on the -12V rail to blow its bung out and halt the PSU's operation (at the bottom of the page). That sounds similar to the way KZGs and KZJs fail. Also, if you look at this thread you'll see a 1000uF 16V 8x20 Chemi-con KZM bulge and the other 1000uF 16V 8x20 Chemi-con KZGs (on the VRM input of a Socket 754 board) look visibly okay (though a couple 6.3V ones failed as usual, and KZM is supposed to be the "long life" version of KZH). I know a couple failures isn't much to go by but knowing Chemi-con's history with KZG, KZJ, and all capacitor series equivalent and lower from them in terms of ESR... it also could have just been that the OP's PSU was bad as well, and the fact that all those VCORE high capacitors are right up against two heatsinks. Or it could be bad seals (why they fail without bloating often). Chemi-con claims, in their datasheets, that their KY, KZE, KZG, and KZJ series of capacitors all use the same "special, low resistivity" electrolyte, yet we all know that KZG and KZJ have a bad formula, but never see KYs and KZEs fail like that ever (KZHs were claimed to have used a "unique water base electrolyte" - may as well be the same thing).
I'm not trying to knock Chemi-con or call out KZHs as unreliable as I have never seen any fail myself. Chemi-con do generally produce excellent quality capacitors.
EDIT: The KZM might be a replacement for a bad KZG but it still kind of looks to me like it's bulging in the second picture which is why I brought it up. It might just be the picture, though.
