Codegen 350XA supply
  • rievax_60
    • May 2012
    • 897
    • australia
    #61
    Re: Codegen 350XA supply
    I have just tried loading the 12v on my 350XA to 6A. Both waveforms change very little. The duty cycle increases by a few percent and the peak drops to 28v.
    milesy, I am curious to see your 12v anode waveform with the 2Ω load.
    • milesy
      • Aug 2012
      • 34
      sure rievax ill post it up later on tonight....trouble is im not getting anywhere near the peak of 28v
      • milesy
        • Aug 2012
        • 34
        here you go rievax.......here is both anode and cathode waveform with no changes to CRO settings just moved the probe......set on 2v/div with a x1 probe
        IMGP9597.jpg by Adrian Miles Photography, on Flickr
        IMGP9596.jpg by Adrian Miles Photography, on Flickr
        • rievax_60
          • May 2012
          • 897
          • australia
          #64
          I think your CRO might be causing the anode waveform to look asymmetrical, because the asymmetry isn't being reflected in the cathode waveform.
          Does it change shape when you change the vertical position. Or try the other channel.
          If the CRO was really set to set on 2v/div, the 12v output would be less than 2v. What was the 12v output measuring?
          Better check the CRO calibration and that the inner vertical gain knob is set to is CAL position if it has that.
          • milesy
            • Aug 2012
            • 34
            ok rievax your sort of right.......what i found was that there is a button on the cro to zoom in on a section of the wave - you can see it in the above picture marked TRIG VIEW PUSH
            for whatever reason this button was activated even though it wasnt in its active state - so where i said i had it on 2v/div above what i was getting was actually peaking at around 30v - so it seems that my wave is correct .......... poor thing is getting a bit old now and is showing a few funny faults.
            so if i said i was confused before - now i really am because i havent actually replaced anything and yet the supply seems to be operating correctly?????
            as for the shape of the wave well i have to agree with you - it doesnt show on the rectified trace so the strange shape must be being caused by the CRO - but i have no idea why
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              • Romania
              #66
              Maybe you need to adjust the probe compensation. Your scope should have a square wave output for that purpose - and if you're lucky it might even work. Otherwise, use a signal generator for this purpose. A soundcard capable of 96 or 192kHz set to generate a 1kHz square wave is fine for this.
              Adjust the compensation trimmer on your CRO probe until the top and bottom of the square wave are parallel with each other and show no overshoot (peaks) or undershoot (rounding of edges).
              A working TV? How boring!
              • milesy
                • Aug 2012
                • 34
                yes the test generator works......never thought of adjusting the cro prope but makes sense........ill have a look tomorrow
                  by sam_sam_sam
                  03-31-2024, 02:12 PM
                • shamsudeen
                  Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                  by shamsudeen
                  Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                  I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                  i know that in linear power supply the noise will be very low comparing to SMPS supply....
                  07-19-2025, 07:14 AM
                • JimBanville
                  Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                  by JimBanville
                  The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                  Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                  I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                  I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                  09-13-2023, 07:21 AM
                • madan1
                  555 based power supply getting too hot
                  by madan1
                  Good day.
                  I have an AC/DC -> DC PWM (rectifier + 555 buck converter) power supply with MDF11n60, which is getting very hot.
                  The input is AC from a transformer and the output powers a 24v dc fan. The power supply is used to regulate the speed of the fan.
                  After several runs on the bench power supply I noticed that the mosfet is reaching 80+C*. The mosfet reads fine on component tester, the thermal paste is changed, the fan is cleaned and with freshly oiled bearings.
                  When powered directly from the bench psu, the fan takes ~0.7A on 12V. The current consumption is similar...
                  06-23-2025, 04:38 PM
