Ultra V series?
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Ultra V series?
    Found a local Ultra ULT-350-P for $20. Is it worth that much? Looks decent for a 350....I've never owned an Ultra PSU before. I know they can be pretty hit or miss though.
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: Ultra V series?
    Not worth it. Lousy capacitors, mediocre design. But definitely a step up from other $20 units.
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      Re: Ultra V series?
      Does it have PFC or is the voltage selector on the inside so it looks like it has PFC? Oh it looks like they put it on the other side....and apparently they're made by Wintech. That's all I need to know right there....haha
      • larrymoencurly
        • Oct 2004
        • 960
        Re: Ultra V series?
        I have a 350W and a 400W Ultra from 6-7 years ago, made by Wintech and with no PFC (voltage selection switch not visible at rear because it's on the front). They still work, and when I pulled several of their Canicon capacitors a couple of years ago, each measured low for ESR. But the first PSU sample had a fan that wouldn't start if the air temp was below 65-68F (fan controller set voltage too low; a kick start capacitor across its thermistor fixed that), and another sample had 1/8" solder balls embedded deeply in the insulation of some high voltage wires, and the circuit board was coated with flux (still gooey) on both sides. One of the 400W units had a small electrolytic capacitor in the low voltage side that almost touched the heatshrink on one of the 120VAC lugs, while the second unit had that capacitor laying flat against the circuit board, well away from the high voltage.
        The instruction booklet for all the units had this misprint:
        • 370forlife
          Large Marge
          • Aug 2008
          • 3112
          Re: Ultra V series?
          Wintech is a company that is very hard to describe. Their units use outdated designs, but can do their labeled wattages, with poor quality soldering and capacitor choices. They often feature OCP and sometimes even Over Temp Protection. I would say this unit is worth a recap and cleaning up.
          • Pentium4
            CapXon Be Gone
            • Sep 2011
            • 3741
            Re: Ultra V series?
            I don't know why but this made me chuckle. Looks like they have weak 12V though. I'm guessing the wattage rating is rated for peak and not continuous right? Didn't Wintech go out of business a few years ago?
            @larry They still work? Did you recap them?
            • 370forlife
              Large Marge
              • Aug 2008
              • 3112
              Re: Ultra V series?
              They hired good engineers, Ultra and Wintech brought the first consumer modular power supply to market, but their units were built to a price...a low one at that. Their engineers decided to design a unit that could do it's labeled wattage, which was more expensive, but made it more cost efficient by using lower quality parts. Now that's not to say they are really well designed, they were still designing to a low price, so they don't have the best ripple control nor best voltage regulation. But, they typically stay in spec and can do it for long periods of time.
              And yes, wintech went belly up a while back. They tried to leave on a good note and design a decent power supply.
              http://www.jonnyguru.com/modules.php...Story3&reid=92
              All UCC capacitors, 87% efficiency, DC-DC, and this was back in 2008! DC-DC was pretty rare to find even in high quality power supplies back then. But it was still overrated, perhaps it was Apevia's fault for labeling it as a 900W, maybe Wintech lied about how much wattage it can do (though as shown in the review there are revisions for higher wattage versions, so I'll go with the former.)
              • 999999999
                • Sep 2006
                • 774
                Re: Ultra V series?
                Corsair Builder Series 430W, $20 delivered after rebate and coupon code (till 6/18 or they sell out):
                http://www.newegg.com/Product/Produc...82E16817139026
                • larrymoencurly
                  • Oct 2004
                  • 960
                  Re: Ultra V series?
                  I never bothered recapping them because the Canicons measured low for ESR and weren't bloated. I bought the Ultras for their parts and to transplant the guts of a noisy Enermax into one (which I did recap -- some of its PC-tur caps have since bloated in storage).
                  A second misprint in the Ultra manual:
                  You'd think it couldn't go in backwards like that, but the plugs were undersized and the socket on a certain cheapo motherboard was oversized just enough to make it possible, without excessive force. I couldn't do that with any other PSU or mobo.
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    Re: Ultra V series?
                    I wouldn't. Having owned two of the 500W units, they suck. They have thin wire, crap caps, and IMHO lame-ass design. I ended up gutting one of them to fix the ultra-specific elements of a Ultra Xfinity 600W that after a tightly squeezed recap is a decent unit.
                    sigpic
                    (Insert witty quote here)
                    • shovenose
                      Send Doge Memes
                      • Aug 2010
                      • 6575
                      Re: Ultra V series?
                      XFINITY??? Hahahahaha
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        Re: Ultra V series?
                        There are a few theads on it... those being everell's ole bluebthread and my 5vsb mod thread.
                        sigpic
                          ASUS Pro Series D320MT-TR362D Pro Series i3-6100 Specification for Upgrade or Repair
                          This specification for the ASUS Pro Series D320MT-TR362D can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-TR362D boardview and Pro Series D320MT-TR362D schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                          09-12-2024, 03:28 PM
                          ASUS Pro Series D310MT-0G32500650 Pro Series G3250 Specification for Upgrade or Repair
                          This specification for the ASUS Pro Series D310MT-0G32500650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D310MT-0G32500650 boardview and Pro Series D310MT-0G32500650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                          ASUS Pro Series D320MT-I564000234 Pro Series i5-6400 Specification for Upgrade or Repair
                          This specification for the ASUS Pro Series D320MT-I564000234 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-I564000234 boardview and Pro Series D320MT-I564000234 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                          ASUS Pro Series D320SF-I564000134 Pro Series i5-6400 Specification for Upgrade or Repair
                          This specification for the ASUS Pro Series D320SF-I564000134 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320SF-I564000134 boardview and Pro Series D320SF-I564000134 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                          ASUS Pro Series D320MT-I564001774 Pro Series i5-6400 Specification for Upgrade or Repair
                          This specification for the ASUS Pro Series D320MT-I564001774 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-I564001774 boardview and Pro Series D320MT-I564001774 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
