Chieftec CFT-750-14c
  • pdavid
    • Jan 2011
    • 279
    • Hungary
    This psu was returned to me after I cleaned it. The owner said that his pc shuts down after a few seconds. Now I have to fix it since "I broke it probably" It turns on but soon after the 5v rail starts dropping to 4 something volts without load. All the other voltages are rock solid and within spec. With load 5V even gets lower like 3.6V and the psu turns off. I doubt only a recap would help on this one. The modular cable soldering is a mess, but there are no short or anything on the pcb. Has anyone experienced this issue with this psu. It's a cwt psh model.
  • pdavid
    • Jan 2011
    • 279
    • Hungary
    Re: Chieftec CFT-750-14c
    I'm going to dissasamble this unit and rework the soldering. The controll board has a lm393, ps229 and a weltrend supervisor chips. I hope it's not one of these giving some trouble. It could be some of the tiny capacitors on this board...
    • pdavid
      • Jan 2011
      • 279
      • Hungary
      I checked the diodes for each voltage rails, changed the filter capacitors. The problem remains. I was playing around with the control board. "Unpluged" the 5 volt protection functions and the unit won't start up. Small capacitors measure ok. I guess that part works fine, but I'm not entirely sure how all the protections work. The problem is with the 5V regulation.
      Need more pics?
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        Does the PSU have minimum load resistors inside? If so, check those and see if they are all reading fine.
        Muh-soggy-knee
        • pdavid
          • Jan 2011
          • 279
          • Hungary
          There is only one 15Ohm 5W resistor on the 12V rail. It's the one on the supervisor pcb. The rest on the secondary are smd resistors. I wired the standy to the 5V voltage input on the ps299 and the symptom remains. All voltages are fine except 5V. The problem may be somewhere else.
          • pdavid
            • Jan 2011
            • 279
            • Hungary
            I figured that the C2 ceramic capacitor was shorted so I changed it to a 0.5 uF. Now 5 volt is 0.1 higher... but still something like 4.2V without load. Still regulation is screwed up so I'm tracking back things.
            Btw should I install the missing vr1 trimmer, if so what value?
            • pdavid
              • Jan 2011
              • 279
              • Hungary
              I still haven't solved this 5V problem. I've been lectured by some pros that it's something with the feedback and that missing vr1 pot isn't important. There may be a faulty component on the primary...
              • mscserbia
                • Dec 2013
                • 17
                • Serbia
                Use another core,new one for 5V rail and rewind it.I had the same problem with 3.3V rail.Try that.
                • rtstorm
                  • Feb 2012
                  • 971
                  • Croatia
                  hi, i have the same problem. +5V go to 3.6V widouth load. Have you managed to get it working?
                  ...the quieter you become the more you are able to hear...
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    Tried checking and/or replacing the 5V rectifier diode? It might be leaky too.
                    Muh-soggy-knee
                    • rtstorm
                      • Feb 2012
                      • 971
                      • Croatia
                      Ok does anybod have a schematic for this so i can find diode?
                      • pdavid
                        • Jan 2011
                        • 279
                        • Hungary
                        I had much trouble fixing this problem on that CWT PSH. As far as I remeber it was something trivial. A bad smd resistor somewhere in the secondary.
                        There is no schematic for this psu platform yet. The 5V diodes are in the middle on the third heatsink.
                        I wish I could help more. Good luck!
                        • AJ847.63e
                          Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                          by AJ847.63e
                          Hi Folks,
                          Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                          I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                          The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                          05-06-2025, 10:37 PM
                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                          09-12-2024, 02:20 PM
                          HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                          This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                          09-06-2024, 10:56 AM
                          HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                          This specification for the HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load, Asset Tag & Testntag boardview and 430 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                          HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                          This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
