Hp e3640a
  • Rob Northen
    • Jan 2010
    • 137
    • Denmark
    Hp e3640a
    I just boght this PS used. It seems to be a quite nice unit.
    I replaced 3 Samwha caps in it, eeek!
    My question is, there are a few UCC SXE and KMG caps in the unit too, that i want to replace, due too their age. I don't have any caps to meet their ESR values, only some that are lower, Panasonic FM.
    Do you think it would be ok to use those ?
    There are no inducters connected to them, so my first thought that it is ok.
  • PeteS in CA
    • Aug 2005
    • 3586
    • USA, Unsure of Planet
    Re: Hp e3640a
    The FMs might be "too good", and cause oscillation. Nichicon PS series or PM series should be closer, and if those aren't good enough, then the PJ series should be about right. Re the lack of inductors, this lab supply might be linear-regulated, and linear regulators don't need output inductors.
    PeteS in CA
    • Rob Northen
      • Jan 2010
      • 137
      • Denmark
      Re: Hp e3640a
      Thanks Pete!
      I also thought they there where a reason for them to choose two diffrent series of caps, and not just for fun.
      And yes, it is indeed a linear PSU. Could you tell a little more about the oscillation. ?
      • eryjus
        by eryjus
        05-10-2023, 11:21 AM
        by momaka
        03-12-2025, 03:42 PM
      • Paxman_Swede
        by Paxman_Swede
        Hello!
        01-14-2025, 09:51 AM
      • captain150
        by captain150
        03-16-2025, 07:34 PM
      • Foetuss
        Gigabyte GA-6OXT :: caps question
        by Foetuss
        Good evening
        I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
        Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
        But I was also suprised about the bigger boys, which are 330µF 25V.
        Could it be they used 25V caps because they were cheaper / available at that time?...
        02-11-2025, 12:22 PM
