HP D530 USDT power supply HP-L1520F3P
  • jdTech
    • Jul 2011
    • 6
    I have a HP D530 USDT (P/N: DB670AV#ABA) PC with a HP-L1520F3P power supply. This supply when down yesterday. I found about 6 swallow caps that I changed. The supply came back up but the STANDBY voltage goes from 5V to 6V when the main supply is turned on (green wire grounded). This will cause the 5V protection zener on the STANDBY line to short. Looking at the PCB traces it looks like the main supply is somehow connected to the STANDBY SMPS chip on the hot side. I have a 5 ohm load on the STANDBY line. Adding another 5 ohm load (2.5 ohm) will drop the STANDBY voltage to 5.15V. I would think a 1A load would be plenty to keep the supply happy and regulating. I also changed the 431 adjustable zener and two 10Uf/50 caps (one the cold side & one on the hot).
    Any ideas?
    Thanks for your time.
    Jim
  • jdTech
    • Jul 2011
    • 6
    Re: HP D530 USDT power supply HP-L1520F3P
    Problem solved! Found that cap C801, a 22uF/50V was defective (read 2.2uF). This cap connect across the two traces that come from the main supply. The STANDBY now reads ~5.1V with no load, 5 ohm, and 2.5 ohms.
    Later!
    Jim
      03-31-2024, 02:12 PM
    • Yanleb
      UN65MU6300FXZC, no standby LED but power supply good. Bad IC1604 25Q40?
      by Yanleb
      My UN65MU6300FXZC is dead and the standby LED stays off. The power supply is good. The main board is BN94-12434A.
      Disconnecting the main board from the power supply makes the backlight come ON.
      I did disconnect the panel cables and the WIFI modules, the board is still dead.
      I did read in many posts that IC1604 25Q40 becomes corrupted. It has proper 3.3 volt on VCC pin 8. I did read that if I post its dump here someone can fix it. Is that right?
      Thanks.
      11-18-2024, 12:34 AM
      07-01-2024, 06:34 AM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • shamsudeen
      Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
      by shamsudeen
      Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
      I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
      i know that in linear power supply the noise will be very low comparing to SMPS supply....
      07-19-2025, 07:14 AM
