which Ir-Rework system is good for soldering Grafikchips
  • xdown
    • Jan 2012
    i would like to buy a rework system for soldering grafikcard on leptop mainboards. but i have no experience whith IR_reworkstation. i have only one hot air rework station....
    so which one is good for soldering grafikcard. maybe some one have some experience...
    thanks in advance
  • Peter_1402
    Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
    by Peter_1402
    Hi Everyone,
    I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
    1. Soldering iron works great
    2. There is a burnt mark on the hot air gun handle.
    I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
    Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
    Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
    Reed switch tested ok with a magnet.
    From the above test, I can conclude...
    07-12-2025, 11:50 AM
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
  • acedogblast
    by acedogblast
    11-02-2024, 05:13 PM
    Multifix 425-01 and 450-01 Rework Flux Datasheet
    REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
    - No Clean Formulations
    - Low residue
    - Range of activity to deal with different component solderability
    - Halide free
    - Suitable for dispensing
    - Compatible with solder coatings and/or No Clean flux cored solder wire product range
    Both products are supplied in syringes or cartridges for application by dispensing....
    10-07-2024, 06:02 AM
  • snow_sg1
    MSI GS73 (MS-16K61) : help me find short (got thermal cam)
    by snow_sg1
    First : I've got a SMD rework station, thermal camera and good soldering station
    This is my first "short" motherboard repair, this laptop was 25€ so no loss, it just for learning. I want to learn how to fixed board because I want this to become my job.
    I've been fixing electronics for 15+ years, but mostly VCR and camcorder.
    So, I checked power adapter pin to ground, no short, then I plugged the charger in, light on charger blink indicating short.
    PQ19 mosfet got HOT straight away (viewed on thermal cam). Checked,...
    09-13-2024, 03:30 PM
