Wt7515 bypass !!!!
  • SWITCHMOOD
    • Aug 2011
    Wt7515 bypass !!!!
    Hi all !, I'm at that point where I'm thinking of taking the plunge. I have a 26" TECHNIKA LCD26-M3. It has a PSM143-310-2-R power supply. The tv will not power up, I've had the PSU apart and checked all the components. It's got 5v but nothing else. The main board is sending the reset signal but the PSU has the dreaded WT7515 management IC. I'm 80 - 90% comfortable that the rest of the
    psu is ok. It's not worth replacing the psu or WT7515. I'm thinking of coupling pin 3 to grnd via a 1k rersistor and pin 14 to pin 13 (5v+) via a 1k resistor (wt7515) and bench testing the psu out of the tv.
    is this a wise thing to do, can anyone help please ?
  • Toasty
    • Jul 2007
    • 4171
    Re: Wt7515 bypass !!!!
    >>has the dreaded WT7515 management IC<<
    Dreaded?
    Which IC version?
    These are in -every one- of thousands of Apple iMac PSU's without issues. Only had one bad in 100+ PSUs. That was from a power surge.
    I'd bet the problem is elsewhere. Likely the start-up caps.
    Have you replaced anything so far?
    Photos?
    Voltages?
    Checked chip datasheet against voltages?
    veritas odium parit
    • SWITCHMOOD
      • Aug 2011
      Thank you Toasty, you have stopped me. I wasn't happy going down that route anyway.
      ok, so although I do electronics as a job, I know very little about tv etc diagnosis. I have removed/ tested all the caps on the psu board with a cap meter along with the diodes, opto isolators, transistors (mosfets) and resistors.
      I have not tested the DM311 PWM DRIVER or transformers, chokes.
      The board is simple as psu's go. I do feel I'm missing something.
      I do not have a manual or schmatic, I'm not sure that I want to subscribe to a datasheet web site at the moment.
      so, i'm not in tune with tv repairs etc. Can I ask anyone, if you were like me, starting to get serious about tv repairs and short of money, would you go out and buy a peak atlas ESR meter ? and it seems that I need a good source of manuals and schematics, where is the best place to get these ?
      can any body help me to see the light ?
      • Fedguy
        • Sep 2011
        • 7
        Does anyone know whereto buy the dreaded WT7515 chip?
        thx
        • Toasty
          • Jul 2007
          • 4171
          Why dreaded? What version?
          Why do you think it's bad?
          veritas odium parit
          • Fedguy
            • Sep 2011
            • 7
            The 5v sense on the chip is there but no output.
            I need to buy them do you know where to get it?
            • Toasty
              • Jul 2007
              • 4171
              Needs all 3 inputs to output.
              Still haven't answered question. What version? In what PSU?
              veritas odium parit
              • Fedguy
                • Sep 2011
                • 7
                AC/Bel 661-3350
                First left green LED comes on Logic board but when you push the power button nothing happens. I have 20v and 5v on the connector.
                We traced the voltages on the WT7515 which has the 5v sense in but no 5V out
                • Toasty
                  • Jul 2007
                  • 4171
                  This belongs in it's own topic, correctly titled.
                  This topic was a different WT7515 *VERSION* about a LCD TV.
                  You're talking about an iMac PSU.
                  Jump to the other topic you started regarding the chip and I'll ask a moderator to re-title that one.
                  Copy your above post to the other topic first.
                  Thanks!
                  Toast
                  veritas odium parit
                  • Fedguy
                    • Sep 2011
                    • 7
                    thx
                    • Spudgun
                      Why doesn't current just bypass faulty capacitors.
                      by Spudgun
                      Hello esteemed members. I appreciate that my question will strike some as being somewhat childishly simple, but it genuine perplexes me! I have repaired several laptops before by removing a faulty capacitor that was short-circuiting the motherboard, whereupon the laptop would then work. For me, it begs the question that, if the current can bypass where the capcitor was when it has been removed, why didn't it just bypass it when it was present and faulty,? I can't get my head round the premise that if the other side of the capacitor is connected to ground, then why doesn't the current simply bypass...
                      04-01-2025, 10:33 AM
                    • Arshad alam4659
                      a1466 smc bypass
                      by Arshad alam4659
                      what is smc bypass and how does it work and how to bypass it i want to know can anyone tell me about it
                      11-09-2024, 08:22 AM
                    • oxonater
                      Apple MacBook Pro A2141 16" IC BYPASS
                      by oxonater
                      Hi everyone hope all are well
                      I need a little expert advice on a issue I have and seeing as this forum is full of clever people I thought ask here as you never know.
                      I recently repaired a logic board 820-01700 which belongs to a 16" 2019 Macbook Pro, however I seem to be missing a component near the T2 Rom chip and is U4730.
                      The schematics say this chip is (M34128-FCS6_P/T) and it also says there is a bypass for it wondered if anyone come across either the IC or the bypass method.
                      I suppose it's worth noting googling the part package brings up various...
                      10-23-2024, 11:21 PM
                    • Yacine007
                      Lenovo yoga c740-5IML MDM bypass
                      by Yacine007
                      hello everyone hope everything good,
                      please can someone help me to bypass this laptop lenovo yoga c740-5iml, i can“t create local account i tried several commands CMD without succes.
                      Model : 81TD
                      SN : PF2AFN38
                      MO : PF9XB0525250
                      MTM : 81TD0067MH
                      Factory ID : JVHFC1
                      MFG : 25/05/20...
                      03-21-2025, 08:53 AM
                    • harounHD
                      Macbook a1989 and a2338 icloud bypass
                      by harounHD
                      Is there a solution for Macbook a1989 and a2338 icloud bypass , i saw a video on youtube of someone using a bootable usb to unlock it
                      02-01-2025, 03:23 AM
