USB ports misbehaving due to PSU
  • berniedd
    • Mar 2007
    • 119
    Just sharing my experience, guys. After we got back from a week's vacation, our trusty 3- year old desktop wouldn't turn on. Simple enough, there was a popped capacitor in the 12-volt line. I replaced the PSU with an older generic 350 watt unit I repaired months earlier with low ESR Samxon caps. Since then, intermittently the USB printer wouldn't print and USB sticks couldn't be read. A reboot usually made it behave.
    After I replaced the output caps in the 3.3, 5 and 12 volt lines in the bad 500 watt PSU with the required low ESR types (Samxon brand again), I swapped it back into the desktop and the USB problems all went away. Seems like the older PSU didn't have enough juice. What confuses me is why only the USB ports were affected. The rest of the computer ran like a top.
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    Re: USB ports misbehaving due to PSU
    USB ports may be using 5vsb for the power. older supples had very little current to supply on the standby rail.
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      FYI- generic no-name PSUs a lot of time need more than caps... things like delta electronics, hipro, ac-bel, seasonic, etc. are ok but others often have cut corners and fraudulent wattage and safety ratings. do you know what brand the 350W unit was?
      sigpic
      (Insert witty quote here)
      • severach
        • Aug 2007
        • 1055
        USB is one of the few places 5v is used directly. PCI I/O uses 3.3v. All the other voltages go through regulators where a little slop on the input won't make any difference.
        sig files are for morons
        • berniedd
          • Mar 2007
          • 119
          It's a CPI (no-name generic).
          • DynaxSC
            GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
            by DynaxSC
            I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
            There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
            The board is generally working now, all PCIe ports are working, Windows installs normally.
            However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
            The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
            03-10-2025, 12:27 PM
            Lenovo ThinkPad P43s Mobile workstation P Specification for Upgrade or Repair
            This specification for the Lenovo ThinkPad P43s Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P43s boardview and P43s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
            09-06-2024, 09:40 AM
