G5 Mac Power Supply Relay
  • SteveNielsen
    Retired Tech
    • Jun 2012
    • 2327
    Re: G5 Mac Power Supply Relay
    We appreciate follow-up posts though.
    • anicolao
      • Aug 2022
      Originally posted by Toasty
      I want to check the output MOSFETs for shorts.
      Unit unplugged from mains.
      Black probe to the common output ground, black wire bunch as before.
      Check each of the 3 output lines (3.3v orange, 5v red, 12v yellow) for any voltage. I don't want you to damage your meter with the next step.
      If not zero, wait until they drop to zero before proceeding.
      If zero, change the meter to the Diode Check setting.
      Check the 3 outputs with the red probe and report the readings.
      You can probe them on P2 if it's easier. Expecting readings of 0.030Ω to 0.300Ω
      I am following this ancient thread trying to troubleshoot an identical supply and have reached this step as the first place where the conclusions might be different.
      Probing the outputs forwards, I get:
      Yellow ~0.160
      Red ~0.020
      Orange ~0.104 after a longer delay
      Probing the outputs in reverse, I get:
      Yellow ~0.135
      Red ~0.020
      Orange ~0.109
      Probing VDC on the cathode side of D2 shows a spike well over 300V. However the voltage here when the supply is off is about 93V not 160V.
      Suggestions welcome, if anyone can remember back this far.
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
        03-31-2024, 02:12 PM
      • JimBanville
        Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
        by JimBanville
        The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
        I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
        09-13-2023, 07:21 AM
      • Babbar
        by Babbar
        04-12-2024, 01:12 AM
      • vletr
        Edac/Drobo Power Supply Fuse
        by vletr
        Looking for next steps on troubleshooting for an external power supply made by EDAC, model EA11011H-120. The power supply was dropped onto a tile floor and initially and briefly worked but the led power indicator light faded out and the power supply showed no signs of life since.
        In disassembly, I found that the large capacitor had leaked and was reading open when measured. The fuse nearest to the AC in had also blown, with no continuity. I ordered a new capacitor and fuse and replaced both, but on power-up with no load the fuse immediately blew.
        05-25-2023, 07:15 AM
