The Young Year PSU here. It works... but at startup 12v is at 6.8v. I put a rail of molexes on it and it'll run a hard drive, with 12v settling at 10.85v. I also noticed that 12v varies quite a bit as the HDD starts up. 5v stays solid.
Even though it's full of fukyoos, it isn't bad caps. Ripple is very low, <30mV on all rails. At first i was reading the scope wrong, my hand was picking up noise and transmitting it to the probe. If the scope is hooked up without me holding the probe, or if i touch the case of the scope (grounded) while holding the probe, the noise goes away, and ripple shows low. Replacing the caps didn't make any difference in output voltage.
Here's the weird part: If a heavy load is put on 5v or 3.3v while the hard drive is connected, 12v will go in spec. If there is no load on 12v, it'll go to over 13v. This basically says that 12v is left out of the feedback loop! Could it really be true?
Edit: Found something cool. Here's how the Chinese load test their supplies... Yes the rail currents are mixed up, but you can figure out which one went where. If you click "Next" there's also temperatures of the various parts... along with estimated life times. Hmm. Those guys actually do their homework, but probably by the time the power supply leaves the factory, there's like half the parts removed.
So the 12v feedback was taken from the main inductor, before any cap, and what reached the 494 was the peak value of the inductor output instead of the actual DC voltage!
