Suspect Bad PS Apple AcBel API 1PC36
  • buz
    quietguy
    • 73
    #61
    Re: Suspect Bad PS Apple AcBel API 1PC36
    Ok ... tell me how to safely jump off a cliff and I'll probably do it ...
    This may take me a bit (fitting it in around some other 'duties') but think I understand the 90%.
    Soldering to Pin2 would be next to the square solder pad. (?)
    Found a piece of 24ga wire should be good (better than the 16ga next choice)
    Need to ask (because I've wondered) - I did the cap soldering with a chisel tip and wonder if I should have used a needle tip. The chisel tip seems to melt the board solder 'almost' before it touches (fast at any rate)?
    Measuring the 3.3/5/12 would be as done when checking voltages initially (using a pinout diagram and instructions)?
    • buz
      quietguy
      • 73
      #62
      Reporting:
      5v test(s) ... pins 1 and 3 ... 4.7v and 4.1v
      12v test(s) ... pins 10 and 24 ... both 8.8v
      3.3v test ... pin 6 ... 3.3v (pins 17, 18 and 19 also tested 3.3v)
      EDIT: Daughter board 5th pin tested ~2.4v occasional drop to ~1.5v
      • buz
        quietguy
        • 73
        #63
        oops .... 5th pin results above was jumpered
        unjumpered 5th pin tested 4.4v
        • Toasty
          • Jul 2007
          • 4171
          #64
          >>Soldering to Pin2 would be next to the square solder pad. (?)<<
          Pin 1 on *most* IC's and such devices is *usually* indicated by a square solder pad.
          It is also *usually* indicated by a dot or dimple on the device itself.
          (see pic 1)
          Pin 2 of M8 is the round pad next to Pin 1 (the square pad on M8). You just tested it yesterday. (see pic 2)
          The 2.4v on DB pin 5 has me concerned as it may not be low enough to fully turn on the opto. The 1.5v is the IC trying to start up and check the voltages.
          I need you to solder the 2 resistors in that package together in parallel. (see pic 3)
          This makes the resistance 1/2 of 1kΩ or 500Ω. That should provide a low enough resistance path to enable the opto fully.
          Rerun the prior test and repost the voltages.
          Toast
          veritas odium parit
          • buz
            quietguy
            • 73
            #65
            Pin 5 jumpered ... 1.0v - 1.6v
            unjumpered .... 5.56v
            • Toasty
              • Jul 2007
              • 4171
              #66
              Other voltages 3/5/12...?
              veritas odium parit
              • buz
                quietguy
                • 73
                #67
                Pin 1 - 4.75
                Pin 3 - 4.1
                Pin 24 - 8.9
                Pin 10 - 8.9
                Pin 6 - 3.3
                with doubled resistor
                • Toasty
                  • Jul 2007
                  • 4171
                  #68
                  Good. Those voltages are a clue that there is something wrong with the 5v/12v line and that's why the supply is not running. Something is not coming up strong enough to run that section. It could be on the input side or one of the diode packs has failed.
                  Let me get some other things together for you to test.
                  Good work!
                  Toast
                  veritas odium parit
                  • buz
                    quietguy
                    • 73
                    #69
                    Thank you a million for hanging in here w me - hate to say it but it's kinda fun on this end.
                    • buz
                      quietguy
                      • 73
                      #70
                      I figured I should be as sure as possible about my soldering to either eliminate it as a current problem or call it 'good enough'. I know it needs improving. The photos are of what I think is the worst of it.
                      Hate to be chasing other troubleshooting unnecessarily.
                      • Toasty
                        • Jul 2007
                        • 4171
                        #71
                        Set DMM to Diode Check function.
                        PSU unplugged and no jumpers.
                        Do the following and hold each for 10 seconds before you take a reading.
                        With DMM black lead on ground / black / negative at mobo plug:
                        5v / red
                        12v / yellow
                        -then reverse-
                        With DMM red lead on ground / black / negative at mobo plug:
                        5v / red
                        12v / yellow
                        Report readings.
                        Toast
                        veritas odium parit
                        • buz
                          quietguy
                          • 73
                          #72
                          Black to pin 12
                          Red to Pins 10 / 21 / 22 / 24
                          Reading = 189
                          Reversed = 155
                          Black to Pin 12
                          Red to Pins 3 / 4 / 15
                          Reading = 23
                          Reversed = 23
                          • Toasty
                            • Jul 2007
                            • 4171
                            #73
                            Please Stop using pin numbers. I have to go look this up -every time-.
                            Use them the way I gave them, please 12v/yellow - 5v/red
                            AND, you can do it right on the board without using the plug.
                            Saying that, the 189 looks suspicious as I get .250
                            Your meter may vary, but isn't there a decimal point? Or a zero in front of the 23?
                            Ok. Time for pics to mark next locations.
                            Toast
                            veritas odium parit
                            • buz
                              quietguy
                              • 73
                              #74
                              Ok - sorry - had no idea it was a problem and understand.
                              I retested at the board and received the same results - no decimals but there is a zero in front of the 23 so - 023.
                              My novice is showing.
                              • Toasty
                                • Jul 2007
                                • 4171
                                #75
                                Did you ever get the solder-wick? The next test will require unsoldering some leads so the items can be tested "out of circuit", but not off the board.
                                I suspect one of the 12v dual-Schottky diode packs to be leaky.
                                This PSU does not have a pi filter on the 12v line, so I'm doubting it's the 12v cap (2200uF/16v) you replaced.
                                veritas odium parit
                                • buz
                                  quietguy
                                  • 73
                                  #76
                                  Yes - got the wick, .10" blue label. Ready when you are.
                                  • Toasty
                                    • Jul 2007
                                    • 4171
                                    #77
                                    Here we go. See the pics as to what these devices are and where to unsolder two legs of each. Wiggle the leads around slightly to make sure you don't have contact to the foil traces. You can use the continuity test on the meter to be sure.
                                    Then test them as individual diodes (4).
                                    They should all give the same readings.
                                    The odd ball will likely be the bad one.
                                    Toast
                                    veritas odium parit
                                    • buz
                                      quietguy
                                      • 73
                                      #78
                                      Took me a bit to figure out the testing but think I got it. The picture shows the 12vShottky and hoping my diagraming isn't too hard to follow.
                                      I number the connections 1, 2, 3 across the 'top' and 4, 5, 6 across the 'bottom' as viewed from the pictures
                                      Tested 1 to 2 and 4 to 5, both read 159
                                      Tested 1 to 3 and 4 to 6, both read 0
                                      • Toasty
                                        • Jul 2007
                                        • 4171
                                        #79
                                        Seems like the 0 readings indicate you still have contact with the foil.
                                        Should have 8 readings. 4 diodes X 2 readings for each.
                                        Start with black on center pins (cathode) and red (anode) on outer. Then reverse the leads to red on center and black on outer.
                                        The desoldered pins should be "loose" in the hole and you should just be touching the pin(s) with the probe on those. Push them a bit to see if they wiggle and the reading changes.
                                        1 - 2
                                        2 - 3
                                        4 - 5
                                        5 - 6
                                        then:
                                        1 - 2
                                        2 - 3
                                        4 - 5
                                        5 - 6
                                        Does that make sense? Sometimes I assume too much.
                                        Toast
                                        veritas odium parit
                                        • Toasty
                                          • Jul 2007
                                          • 4171
                                          #80
                                          Actually, unsolder the remaining two pins. If everything is good, the first 4 readings should match and the second 4 should read infinite (open).
                                          0 = zero ohms, as if the meter leads are touched together
                                          Infinite would be as if the leads were not touched together. The meter should not register anything.
                                          veritas odium parit
                                          • jetblue
                                            need help with Apple AcBel 1PC36
                                            by jetblue
                                            hi,i recently recapped a non responsive acbel 1pc36 power supply. i need to know what is the plugged in state for this supply with no jumper wire on the on plug pins.
                                            is it normal for the fans to come on and meter readings on the plug to be normal? or does the start pin need to be bridged to get any readings from the plug?
                                            it seems like its stuck on on and not standby from what i read on the threads.
                                            its not cycloning only when i bridge the other set of pins will it do that but im not sure if its because im not plugging the pins right because after a while it stops....
                                            09-06-2022, 11:51 AM
                                          • a_p3rson
                                            Apple Watch Charging Controller Schematics / Boardview - 820-02601
                                            by a_p3rson
                                            Hi there,
                                            I'm looking for anyone who might have information on Apple's embedded Apple Watch charging daughterboard, ID 820-02601. This is currently used by Anker in their Apple Watch charging products, but likely by other Apple partner brands as well.
                                            You can see the board referenced in ChargerLab's teardown of the Anker Y1811 3-in-1 MagSafe cube - they discuss the "Apple Watch wireless charging circuit" about 2/3rds down the page. It's not pictured, but the board ID reads 820-02601-A, which sure sounds like Apple.
                                            This daughterboard uses an interesting...
                                            04-21-2025, 11:41 PM
                                            HP ProDesk 600 G5 + Apple AirPods ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                            This specification for the HP ProDesk 600 G5 + Apple AirPods can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + Apple AirPods boardview and ProDesk 600 G5 + Apple AirPods schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                            09-12-2024, 02:30 PM
                                            HP EliteBook 830 G6 + Apple AirPods Pro Notebook 800 Specification for Upgrade or Repair
                                            This specification for the HP EliteBook 830 G6 + Apple AirPods Pro Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 830 G6 + Apple AirPods Pro boardview and 830 G6 + Apple AirPods Pro schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 07:50 PM
                                            HP EliteBook 840 G6 + Apple AirPods Pro Notebook 800 Specification for Upgrade or Repair
                                            This specification for the HP EliteBook 840 G6 + Apple AirPods Pro Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + Apple AirPods Pro boardview and 840 G6 + Apple AirPods Pro schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
