Suspect Bad PS Apple AcBel API 1PC36
  • Toasty
    • Jul 2007
    • 4171
    Re: Suspect Bad PS Apple AcBel API 1PC36
    That's UCC - the little shield emblem.
    LTec links to PDF files and you need the Adobe Reader plugin installed for your browser.
    Attached PDF's for your convenience.
    C43 is an LTec TK.
    C13, 35, 41, 59 are UCC KY.
    Toast
    veritas odium parit
    • buz
      quietguy
      • 73
      Well you're a champ Toasty .... thank you! Some fish giving going on on one hand but feel like I'm working for it on the other.
      Seems an answer always produces questions. I've 'finished' as best I can. The L-Tec data sheets confused me, they're laid out differently than the Teapo and UCC data sheets. So I'm not real confident of the values I came up with for the L-Tec's.
      Then, when I was getting the UCC caps done I noticed the different values depending on a temperature/impedance value. I believe all my values came from the 20ÂșC column - so either they're all wrong or 'mostly' right.
      Thank you for the series correction on C43.
      • buz
        quietguy
        • 73
        So if my ripple and Z values are correct, then do I match those values when shopping for replacements? (Still am concerned w the L-Tec ripple and Z numbers)
        Which brands are most respected?
        I've seen here (in a mobo thread) that using a replacement with a higher V rating can be ok, is it true for PS's?
        I've also read that larger diameter caps are ok as long as there is room physically??
        • Toasty
          • Jul 2007
          • 4171
          All that info is in here.......
          Z = impedance = ESR as I said before (post 19).
          Equal or better with ESR and Ripple.
          ESR - lower is better: 0.02mΩ is better than 0.04mΩ
          Ripple - higher is better: 1500mA is better than 1200mA
          Voltage - one "step" up is considered acceptable: 2.5v->4v->6.3v->10v->16v->25v->35v->50v->63v
          Sometimes the step up gives you better ratings too.
          Diameter is the hardest to fit in a lot of units. You've plenty of height clearance here, so that should not be an issue.
          Most replacements you need are available in the sizes you already have. One may need to nudge a coil a bit to fit a 12.5 in where a 10 was (C21).
          Caps that would be good for this supply.
          Look at each ones datasheets and figure what will work for you here. Obtaining them all from one source will save costs for shipping.
          Nichicon - HE, PM, PW
          UCC - KY, LXY
          Panasonic - FC
          Then you need to find who carries which and are in stock.
          www.digikey.com
          www.mouser.com
          Always tick the "stocked" or "in stock" boxes when searching those sites.
          Happy Hunting!
          Toast
          veritas odium parit
          • buz
            quietguy
            • 73
            Before I do any ordering ... wonder if you'd take a quick look at my selections. You didn't list the Panasonic FM series but it was listed elsewhere in the forum ... thinking there could be a reason you didn't list it.
            I see that C21 is hard to come by in a 10mm and agree a 12.5 could be 'wedged' in. Also, C10 is drawn on the board much bigger than 10mm - any reason to upsize it?
            Thanks for all your help & (patience)!!!
            EDIT: From my spreadsheet it looks like I may as well order all Panasonic if I can.
            • Toasty
              • Jul 2007
              • 4171
              #26
              FM's are okay, but you run the risk of overkill on a PSU when it comes to ESR. Ripple handling IMO can never be too much, but too low an ESR can toss the balance off on the filtering as designed.
              School's still out on that, and I've not had a bad experience with that either. But, there is caution in the rumblings about the forums regarding others who ran into a higher ripple when using "ultra-grade" caps.
              That's why I did not give the FM's as a choice. FC is lower than the HE in one line, and equal to the PW in the other (you'll notice that they closely follow each other in the sheets {makes one wonder... } ). In both cases, sticking with the KY originals is likely a better choice.
              Toast
              [EDIT: C10 - whatever is at hand from the manufacturer is what goes. If 10mm are cheaper this week... ]
              veritas odium parit
              • Toasty
                • Jul 2007
                • 4171
                #27
                Also, very nice job on the charting and cap worksheet. Good to see you're getting the hang of it.
                T
                veritas odium parit
                • buz
                  quietguy
                  • 73
                  #28
                  Getting the hang of it requires a good 'guide' - Seriously!!
                  I see now that because I find an option on the data sheets, doesn't mean Digi-key or Mouser will offer it. I've gone through both vendors and made a list of replacements. The new lists are a 'cry' from those I had listed from the data sheets but similar in stats. . Anyway, I don't know whether I need a 'rubber stamp' or not ... as in, "oh those will work" or "oops, better swap out ..... ". It appears to me that perhaps those from Digi-key may be the better of the two.
                  C10 is the loner for finding the right physical size replacement. Its a 10mm and the only caps I could find with the right uF/V are 12.5mm. It's spot on the board is drawn as a 12.5mm.
                  Funny how across brands and series the stats are identical.
                  • Toasty
                    • Jul 2007
                    • 4171
                    #29
                    C10 is okay at 12.5mm.
                    C21 - you'll need to "adjust" the coil next to it to get a good fit.
                    C8 - 47/25 - KZE ; Specs on DK don't match your sheet for PW {180/600} looks like it was HE.
                    KZE is 250/300 and 2Âą cheaper
                    C35 - 470/35 - KZE and 12Âą cheaper --> FC is below original spec
                    C21 - 3300/10 - KZE too ...and it's 20Âą cheaper ...sensing a pattern yet ?
                    Toast
                    [Double check me on these. It's easy to go bug-eyed on those sites. ]
                    veritas odium parit
                    • buz
                      quietguy
                      • 73
                      #30
                      Did you use one or the other of the two sites? (Digi-key or Mouser) .... maybe it doesn't matter. I'll make the changes in a few mins.
                      • buz
                        quietguy
                        • 73
                        #31
                        Pretty much answered my own question (above) - DK had everyone you pointed out. Much better stats on those KZEs.
                        Not real sure about the pattern other than the UCC's are original equipment with seriously better stats.
                        Thanks for that on C10/21. Guess I'll get my order in (may check it again) - am anxious to see if the ol' girl will start again. Any bets?
                        • Toasty
                          • Jul 2007
                          • 4171
                          #32
                          No bets. It -will- work.
                          veritas odium parit
                          • buz
                            quietguy
                            • 73
                            #33
                            Hats off to Digi-key. Order placed the 14th and delivered the 16th from MN to OR, surprised me!!! Really didn't expect the order till next week.
                            So any last min tips on going back the other way? Think I'm gonna look some more for that 1/32nd inch (.031") solder ... other than that idk, just put it back like it was.
                            • buz
                              quietguy
                              • 73
                              #34
                              Found the solder, checked the order - looks like it's time. Wish me luck.
                              • buz
                                quietguy
                                • 73
                                #35
                                - well there's no joy. Same symptoms as before. Fans pulse, mobo LED flashes on and .... nothing. Dang it!!
                                Any thoughts?
                                • Toasty
                                  • Jul 2007
                                  • 4171
                                  #36
                                  Jumpered on, does the PSU run by itself?
                                  veritas odium parit
                                  • buz
                                    quietguy
                                    • 73
                                    #37
                                    Jumpered on?
                                    • buz
                                      quietguy
                                      • 73
                                      #38
                                      I'm bummed ... sort of. I was getting ready to check the pin out and tried a start up. Recalled a kb article about the power buttons on these machines being off center from the switch behind and 'may' need to press the pwr at the '11 oclock' position - I did and it start up.
                                      Why bummed? Well, wondering .... only came across this after committing to the PS rebuild. In the bigger picture, I certainly don't regret 'freshening' the PS and the learning involved.
                                      How do you jumper the PSU?
                                      • buz
                                        quietguy
                                        • 73
                                        #39
                                        Toast ... realized I may have sounded ungrateful for all your help and that is NOT the case. It's running and thank you.
                                        • Toasty
                                          • Jul 2007
                                          • 4171
                                          #40
                                          Glad you got it working! The "freshening" certainly won't hurt in the long run. It might actually be running 5 years from now.
                                          Look up the other threads in here. There is a pinout diagram in one of them.
                                          Also, coming off the PSU board, the wire was marked ON/OFF or some such. I think it's the Green wire.
                                          Disconnected from computer and plugged into wall outlet, jumper from that to any black(ground) and it should come on. I don't know for sure if this requires a load to run. Some do.
                                          Toast
                                          veritas odium parit
                                          • jetblue
                                            need help with Apple AcBel 1PC36
                                            by jetblue
                                            hi,i recently recapped a non responsive acbel 1pc36 power supply. i need to know what is the plugged in state for this supply with no jumper wire on the on plug pins.
                                            is it normal for the fans to come on and meter readings on the plug to be normal? or does the start pin need to be bridged to get any readings from the plug?
                                            it seems like its stuck on on and not standby from what i read on the threads.
                                            its not cycloning only when i bridge the other set of pins will it do that but im not sure if its because im not plugging the pins right because after a while it stops....
                                            09-06-2022, 11:51 AM
                                          • a_p3rson
                                            Apple Watch Charging Controller Schematics / Boardview - 820-02601
                                            by a_p3rson
                                            Hi there,
                                            I'm looking for anyone who might have information on Apple's embedded Apple Watch charging daughterboard, ID 820-02601. This is currently used by Anker in their Apple Watch charging products, but likely by other Apple partner brands as well.
                                            You can see the board referenced in ChargerLab's teardown of the Anker Y1811 3-in-1 MagSafe cube - they discuss the "Apple Watch wireless charging circuit" about 2/3rds down the page. It's not pictured, but the board ID reads 820-02601-A, which sure sounds like Apple.
                                            This daughterboard uses an interesting...
                                            04-21-2025, 11:41 PM
                                            HP ProDesk 600 G5 + Apple AirPods ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                            This specification for the HP ProDesk 600 G5 + Apple AirPods can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + Apple AirPods boardview and ProDesk 600 G5 + Apple AirPods schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                            09-12-2024, 02:30 PM
                                            HP ProBook 450 G7 + Apple AirPods Pro Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 450 G7 + Apple AirPods Pro Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G7 + Apple AirPods Pro boardview and 450 G7 + Apple AirPods Pro schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 07:50 PM
