Viewsonic PJ50D DLP Projector cuts out
  • dzak66
    • Jan 2009
    does anyone have any info on Viewsonic PJ50D.
    My unit cuts out after about 30 seconds use.
    I suspect the power supply is faulty (possibly overheating) as the power indicator light goes out also and doesn't come back on for about 10 minutes.
    I pulled it down and carried out a visual inspection on the board and caps, all seems ok so i resoldered the board.
    Worked for one night but the problem returned the next day.
    Any ideas of common faults or links to circuit data etc would be appreciated
    dzak
  • dzak66
    • Jan 2009
    Re: Viewsonic PJ50D DLP Projector cuts out
    what about a good source for smps unit repairs/testing & info
    • dzak66
      • Jan 2009
      Re: Viewsonic PJ503D DLP Projector cuts out
      woops stuffed up the model number in the title.
      Any help peeps?
        master hoarder
        • May 2008
        • 12170
        Check all of the solder joints really carefully with a magnifying glass. Quite possible that some of them may be cracked.
        If possible, post some pictures of the boards here (but please use this forum's Manage Attachments feature rather than using an off-site host). Hopefully, that will also get more people to respond.
        • dzak66
          • Jan 2009
          Thanks,
          I have already resoldered the power supply board but didn't find any dodgy joints. I will pull it apart again soon and recheck and take some photos.
          What i have also found is that if i leave the unit on standby it will always cut out after 30 seconds or so, but if I have it switched off at the wall until i am ready to use it the projector may go all night without a problem ???
            master hoarder
            • May 2008
            • 12170
            Interesting. Perhaps the standby section of the power supply is doing something funny when it warms up. Definitely post some pictures, especially of the power supply.
            • nobbnobb1
              Bose Companion 5 - Unit Powers On then Cuts Off Shortly After
              by nobbnobb1
              Hi guys,
              Trying to salvage a Bose Companion 5 computer speaker system that powers off shortly after powering on. It's got a primary USB input (built in DAC) and an aux 3.5mm input. The USB appears to be the primarily source that tells the unit to power on (control pod LED goes green) as the unit has no power switch.
              When I first connect power to the unit, plug in the USB, it will play audio nicely for a minute before it drops out and the unit appears to go into standby (control pod LED goes red). It stays in standby and I cannot seem to power it back on without physically...
              02-03-2022, 11:14 AM
              Lenovo ThinkPad P51s + ThinkPad Stack Mobile Projector Mobile workstation P Specification for Upgrade or Repair
              This specification for the Lenovo ThinkPad P51s + ThinkPad Stack Mobile Projector Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P51s + ThinkPad Stack Mobile Projector boardview and P51s + ThinkPad Stack Mobile Projector schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
              09-06-2024, 06:11 AM
            • ngml
              Repair of an LG split AC system indoor unit PCB
              by ngml
              I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
              This indicates an error in the communication between the outdoor and the indoor unit.
              The outdoor unit is fine, so the problem is the indoor PCB.
              The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
              I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
              Does anybody have the schematics of this board,...
              02-01-2025, 12:55 PM
            • lostone
              Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
              by lostone
              Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
              First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
              When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
              05-19-2024, 11:40 AM
            • Gjackson
              Air-conditioning unit power supply failing to power up
              by Gjackson
              Hi all, I managed to narrow down which PCB was causing my Haier AC to throw out an E7 error code (E7 indicates that the indoor unit and outdoor unit cannot communicate). I found that the outdoor unit power board which gives 5v and 15v to the outdoor unit module board fails to fully power up.. The power Led starts to fade in incredibly slowly and the 5v and 15v power buses jump around like crazy and never reach their required voltage. I unplugged the module board from the power board and the power board powered up fine! It had a steady 5v and 15v out and the power LED came on instantly and Bright....
              01-08-2022, 09:24 AM
