Dead Trutech PLV16190 Power Supply LS1904006 D484
  • wilywizzzz
    • Jan 2011
    • 10
    It's TV,LCD Monitor
    I pulled the Cap out thinking they all 3 of them are the same
    All SAMXON GFCMD
    2 Of them were 1200uF 25V
    1 of them was 1500uF 16v
    any advice where to buy those 3 and also I read I have to go up
    and where can I put them I got mixed up
  • Andreas_de
    Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
    by Andreas_de
    Hello!
    i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
    Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
    Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
    04-12-2025, 10:38 AM
    by sam_sam_sam
    03-31-2024, 02:12 PM
  • kevin_allein
    Samsung QE 75 Q 7 FGMTZG Power Supply dead
    by kevin_allein
    Hi, have this Samsung QE 75 Q 7 FGMTZG TV with no function. First analysis shows the power supply board is dead and fuse blown. Power Supply has the number BN94-11439A. I did short circuit test transistor and diodes and those do not appear to have shorts. I must admit I did not look at every single data sheet.
    In the TV was some black dust residue, so probably one of the electrolytic caps blew, but they do not show short either.
    Does anyone have schematics for that board ?
    Any good tip, what could be the issue ?
    02-27-2025, 12:15 PM
  • khalillll
    maxipower 400W Dead power supply repair
    by khalillll
    The power supply was completely dead. Voltage reached the main capacitors, but nothing after that.
    After checking, I replaced the UTC7606D IC to restore the 5VSB.
    I using SDC606U as a replacement, but it didn’t work — possibly the IC itself was faulty.
    Replaced it again with another UTC7606D.
    Result: 5VSB came back, but still nothing — no 12V, 5V, or 3.3V.
    After checking again, I think the issue was with the UTC7520D IC.
    Replaced it with a WT7520.
    Result: PSU fully working again
    09-27-2025, 05:06 AM
