ASUS VH222H - PowerSupply Problem
  • dkp0h
    • Jan 2011
    Hello, i'm french and really noob on electronic but i'm very curious and interested to solve some (maybe) easy problem...
    So i hope i can learn more with your experience....
    My screen : ASUS VH222H
    One day a strong odor was noted in my room so i decided to open it to find out what it was...so take a look at the photos :
    PowerSupply CARD :
    From these first photos what about feasibility ?? :O )
    Do you think with such burn pcb, i can still try something ?
    Here it is the component involve :
    (You can notice some traces of burn)
    First of all, I hope you have enough elements to give me your opinion about my problem...if i can change this component and get back correctly on the pcb...
    Thank You...
    dkp0h
    (FRANCE)
  • seanc
    • Nov 2008
    • 1319
    Re: ASUS VH222H - PowerSupply Problem
    Well looking at the set of connectors opposite side of the transformer, I can see no component.
    Are those pins opposite, covered in glue?
    I wonder if there was a bad solder joint which has gotten hot and melted the glue...
    As for why it got hot, that's another question. Perhaps the transformer has shorted.
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      Arcover in high voltage section. Could be bad (open) CCFL lamp and failed overvoltage protection, could be just that some metallic debris landed inside... Scrape the burnt material off and try to power the monitor again. See what that gives. It's important that you get the affected area very clean otherwise it'll arc again (burnt stuff = carbon, carbon is conductive). If the burn is deep use a dremel tool to cut that part of the board out, just don't damage the traces. There's plenty of space there so if you are careful it should be easy. Remove the transformer before attempting such a job though.
      Also i see that the board has Elite capacitors. Better replace them even though they are not bad yet, they will go bad soon.
      A working TV? How boring!
      • goodpsusearch
        • Oct 2009
        • 2850
        • Greece
        I thought that Elite were good caps but not low esr....
        • TheLaw
          • Jan 2011
          • 477
          Nah. They are pretty terrible.
          • Behemot
            • 4845
            • CZ
            Didn't you mean Elna? Those are good but not low ESR IIRC.
            • goodpsusearch
              • Oct 2009
              • 2850
              • Greece
              Yes... sorry I mixed them up...
              • dkp0h
                • Jan 2011
                Thank you guys, happy to see that it's possible to fix....
                Thx 'Th3_uN1Qu3', i'll do with your method, clean it, replace transformer and try it...
                If i need to change this transformer, which component could replace it ?
                d!K
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  Look it up at www.lcdparts.net, they should have it.
                  • AtelierRepa
                    ASUS X712JA problem
                    by AtelierRepa
                    I have a problem with the bios, let me explain.
                    With BIOS 1, the pc takes +- 30 seconds to display the ASUS logo (black screen) and to boot.
                    I did a clear ME, my black screen problem for 30 seconds at boot is solved, it gives me directly the display and boots quickly.
                    My problem is that now, once the charger is plugged in and I put a slight load on the processor, it bogs down to 0.39GHz...
                    The only solution is to unplug the charger to get the cpu back up to speed. But as soon as I plug in the charger, it goes straight back down....
                    06-15-2024, 04:33 AM
                  • Dobrowol
                    Asus GA402RK keyboard and kb backlight problem
                    by Dobrowol
                    Hi. I have a problem with Asus ROG GA402RK. The keyboard suddenly stopped working along with the kb backlight. I replaced the keyboard and the ITE KBC chip and the problem is still the same. I don't see any passive elements that look damaged. Does anyone have an idea?
                    04-28-2025, 04:30 PM
                    ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook CX1 Specification for Upgrade or Repair
                    This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...
                    09-07-2024, 02:50 AM
                    ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook 15 Specification for Upgrade or Repair
                    This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                    ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook Specification for Upgrade or Repair
                    This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
