Component without datasheet IC's labeled "IN1S313I" and"IN1S424I"
  • Alimash
    • Jul 2019
    • 31
    • Lebanon
    Hello
    I am troubleshooting a couple of coolmaster ATX power supplies.
    I suspected that the faulty components are the sps supervisor IC's labeled "IN1S313I" and"IN1S424I".
    I couldn't find any information about them online exept for their name, role and the manufacturer witch is "infsitronix".
    No datasheet, no pinout, i even tried to email infsitronix but no reply so far.
    I can't find a supplier to buy it either.
    Any help of how to test it and where to buy/order it is appreciated.
    Regards.
    Last edited by SMDFlea; 10-29-2023, 10:42 AM. Reason: IC's labeled "IN1S313I" and"IN1S424I"
  • Alimash
    • Jul 2019
    • 31
    • Lebanon
    Re: Component without datasheet IC's labeled "IN1S313I" and"IN1S424I"
    • lotas
      • Jan 2016
      • 4708
      • Russia
      IN1S313I-sag = WT7510A = EST7610A and presumably = PS113A
      • Alimash
        • Jul 2019
        • 31
        • Lebanon
        Thank lotas,this is very helpful since the Weltrend ic's can be purchased while Infsitronix company don't have distributors (that i know of) and didn't reply to my email.
        What about the IN1S424I?
        I hope these pictures help
        • lotas
          • Jan 2016
          • 4708
          • Russia
          I can’t say anything about IN1S424I, probably some kind of relabeling of another chip.
          • Iceking007
            Audio Driver/ Controller IC labeled GAD SHM? Datasheet
            by Iceking007
            Could anyone provide me with some information on an IC labeled GAD SHM?
            This is some sort of audio driver, it connects directly to left and right speakers via some inline resistors (small value of course).
            I've attached an image of the chip on board, I counted 20 pins. It might be some sort of op amp; it isn't the primary audio processor, as there is a separate dedicated chip for that.
            Thank you for your time....
            10-23-2022, 12:41 AM
          • electomech-fixer
            First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
            by electomech-fixer
            I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
            I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
            09-15-2025, 01:42 AM
          • SoulFreeze
            Help finding datasheet for component marked G34662
            by SoulFreeze
            Hi, pulled this component, (I'm assuming it's a MosFET) from an LED COB video light. Im trying to find the datasheet so I can find an equivalent replacement but no luck. Any assistance with the datasheet would be appreciated.
            Failing that, a way to pick a suitable replacement component? If it's indeed a switching fet, I'm assuming I might need to measure the switching clock frequency and find a component that meets the power capacity?
            Its a pair of them driving a 130w Light. Takes in 19volts. I can borrow a scope to measure the switching freq....
            05-01-2025, 03:56 AM
          • Rainbow_Chameleon
            Searching Datasheet for AM113 IC by O2MICRO
            by Rainbow_Chameleon
            I got a dead HD6950 on Ebay to try my luck and repair it. There were a few broken off capacitors that I already replaced.
            Measuring the PCI-E lanes I got somewhat weird measurements, the gpu might or might not be dead.
            If I plug the GPU in, the core heats up and I also get VCore but on two inductors that measure 16 and 60 Ohms respectively (Memory and PEX I guess) there is no voltage.
            On one of the two buck-controllers (APW7165) the enable pin is pulled to GND and the other controller I just cannot find a datasheet for.
            So if anyone has a datasheet or at least...
            01-23-2025, 12:03 PM
            Surface Mount Fuses Fundamentals Datasheet
            TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
            TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
            10-07-2024, 06:07 AM
