I'm sure some of you are familiar with this brand who normally is in Europe. I want to use this in a very low powered system. The PSU in this system now is way overpowered and I want to use it for something else.
This system at its peak uses a mere 75W so this thing will be fine I believe. However, I do think it needs some modifications.
Overhead shot:
Look at those input wires! Nice. They're all 18 gauge with lots of insulation. The input is solid and is only missing MOVs. Speaking of, does someone know of a MOV part that I can have on hand from Digi-Key or Mouser in general to have on hand for PSUs that don't come with MOVs?
The switchers are 13007 TO-220 unfortunately with a small heatsink but I won't be pushing this past maaaybe 120W peak.
The transformer is of good size, no issues there.
On the secondary, we've got:
45A FET on the 3.3V (40N03GP) This must be derived from the 5V?
x2 20A schottky on the 5V (S20C45C)
20A ultra fast on 12V (U20C20C)
Here's my main concern with this, there is only one 1000uF 16V (!) cap on the 12V rail! And they jumpered where a PI coil should be. I was going to put in a 2200uF 16V Chemi-Con KYB. The thing is, the ESR is half of the original. Would it be better to put in a 1000uF 16V Rubycon YXJ and then add in a PI coil from the 12V rail of a scrap Solytech PSU?
Overhead shot:
That won't do them any favors.
But even if you used a 80Plus Bronze or Silver PSU, it would still probably waste as much power, unless it was a very low-power -rated PSU (like under 150 watts.) Most PSUs, regardless of 80Plus ratings, still tend to get rather poor efficiency under 10% load.
