BE QUIET! BQT P5-420-S1.3 troubleshooting
  • yokoono
    • Apr 2010
    • 502
    I have BTQ P5-420W-S1.3.
    PWM controller (8 pins) for +5vSB it"s exploded. What IC work?
    What is the value of CX (exploded)?.
    ps. Sorry for my bad english.
  • POM_MJ
    • Aug 2009
    • 228
    Re: BE QUIET! BQT P5-420-S1.3 troubleshooting
    I thought the circuit wasn't 5VSB part, that could be main switching part.
    the PWM chip might be UC3842/UC3843.
    see the reference circuit attached.
    | AMD Phenom II X2 550BE | GIGABYTE GA-MA790FXT-UD5P | GeIL DDR3 Ultra 2x2GB 1600C7 |
    | XFX GTS250 DDR3 512MB | Dell H525EF-00 | Lancool PC-K62 Black | Samsung 2232GW |
    | 2xWD7500AYYS | 2xHD322GJ Raid0 |
    • yokoono
      • Apr 2010
      • 502
      With uc3842 or uc3843 or uc3844 +5vsb is not standing.
      Variable between 4v and 4,5v (pulsate).
      • POM_MJ
        • Aug 2009
        • 228
        I mean, the PWM chip (might be UC384x) and the transistor in your circuit drawing in #1 post are parts of main switching, not 5VSB circuit.
        the 5VSB circuit wasn't use the PWM chip UC384x, it could be 2 transistors circuit.
        and your 5VSB problem seem to be badcaps symptom.
        • yokoono
          • Apr 2010
          • 502
          No. 5VSB is witch ic pwm and n-mosfet.
          Power circuit is witch TL494 and 2 transistors.
          The caps it"s good.
          • POM_MJ
            • Aug 2009
            • 228
            may be your PSU is using Fuhjiyuu caps, like this one (images from google).
            Fuhjiyuu are known crap caps, check your PSU caps.
            • POM_MJ
              • Aug 2009
              • 228
              Ok, I was wrong.
              the PWM is UC3842 with 2SK2645.
              Firstly, please try to change both 5VSB caps. I guess they're bad.
              • POM_MJ
                • Aug 2009
                • 228
                and this one.
                • yokoono
                  • Apr 2010
                  • 502
                  URAAA! That"s it!
                  I change the caps. And the value for cx?
                  • POM_MJ
                    • Aug 2009
                    • 228
                    CX is used in soft-clamp circuit, I guess it value is 0.01uF/1KV.
                    • yokoono
                      • Apr 2010
                      • 502
                      Thank you very much POM-MJ.
                      You are a gentelman.
                      • POM_MJ
                        • Aug 2009
                        • 228
                        You are welcome.
                        • yokoono
                          • Apr 2010
                          • 502
                          Don"t work.
                          POM-MJ, please, what is wrong?
                          • POM_MJ
                            • Aug 2009
                            • 228
                            I would check all components in the circuit, include TL431 on secondary side.
                            may be some resistors were burnt.
                            Did you have change 5VSB capacitors?
                            I thought the PWM exploded due to heavy work because of leakage capacitors on secondary side.
                            if you post details of your PSU pictures, would help much.
                            • yokoono
                              • Apr 2010
                              • 502
                              I change all capacitors, tl431, 1N4148, DZ18V, MOSFET,optocuplor and resistors (all,all).
                              Maybe the value(s) of component(s) isn"t correct(s). Were blacks.
                              • POM_MJ
                                • Aug 2009
                                • 228
                                your PSU is now "+5vsb is not standing ,variable between 4v and 4,5v (pulsate)", right?
                                Which component(s) were burnt into black?
                                • yokoono
                                  • Apr 2010
                                  • 502
                                  In this moment with the values of electrical diagram:
                                  U(v) pin 7 - 11-12v valiable
                                  U(v) +5vsb - 2v but the electric current through mosfet is too big.
                                  The frequency of uc3844 is 190khz.
                                  • POM_MJ
                                    • Aug 2009
                                    • 228
                                    The 5vsb transformer could be burnt (wires short).
                                    try to replace with a known good one for test.
                                    • yokoono
                                      • Apr 2010
                                      • 502
                                      Big problem.
                                      • POM_MJ
                                        • Aug 2009
                                        • 228
                                        Are you replace PWM chip with UC3844 ?
                                        I thought it's caused the problem.
                                        UC3844 has 50% duty cycle max., UC3842 has 100% duty cycle max.
                                        • ShadowAi
                                          ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                                          by ShadowAi
                                          Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                                          Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                                          After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                                          03-15-2024, 10:46 AM
                                        • прямо
                                          Viper22A 5VSB circuit
                                          by прямо
                                          So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
                                          In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
                                          01-13-2024, 07:05 PM
                                        • kotel studios
                                          FSP300-60GTF - no 5VSB, PS_ON; 5VSB carnage
                                          by kotel studios
                                          Finally replaced all of the shorted 4148's and resistors and an blown tl431 on my FSP300-60GTF after 5VSB going crazy and destroying it self. Those components also made the secondary transistors appear shorted (while in reality they weren't).
                                          Powered it on through my dim bulb tester and they (bulbs) only flash once meaning primary caps are getting charged, but that's it. No 5VSB, PS_ON voltages.
                                          I am sure I have replaced the components correctly and that there weren't any shorted/blown traces left.
                                          Any ideas where to go next?
                                          02-23-2025, 11:47 AM
                                        • blues_spirit
                                          practical courses for troubleshooting pc motherboards
                                          by blues_spirit
                                          Hello from France,
                                          mon2 kindly advised me to post a thread to ask the question(s) I'm concerned about. I'm new to the forum and I'm looking for practical courses for troubleshooting pc motherboards especially laptops in Europe, if possible in France. I have been a computer network system administrator and a corrector of administration modules for automated programs under Unix. But I really miss the practical "ops" side of troubleshooting. So I would like to start from the beginning: 1.8V, 3.3V, 5V and 19V tests for example, etc...
                                          Do you think this is feasible for me? I...
                                          12-18-2022, 12:56 PM
                                        • Bivolalbert
                                          Help figuring out the resistance of this exploded resistor. gtx 1060 6gb inno3d compact
                                          by Bivolalbert
                                          Hello,I need help figuring out the resistance of this exploded resistor. I'm pretty sure it's the one labeled R37. I tried measuring it with a multimeter, but I got different values each time, probably because it's exploded. If you have a schematic, it would be really helpful!
                                          Its a gtx 1060 6gb inno3d compact, i you have schematic it would be very helpful....
                                          02-13-2025, 10:30 AM
