Am having trouble finding an A6351 chip to replace the fried one in the 5VSB circuit of my ATX-300-12Z power supply. Have read previous discussions about this chip here but haven't seen mention of a source for them. Thanks.
Need A6351 I.C.
Tags: None
Re: Need A6351 I.C.
http://www.findchips.com/
finds one vendor with no stock, but give them a call to see if they can special order.Last edited by retiredcaps; 09-04-2010, 06:05 PM.--- begin sig file ---
--- end sig file --- -
Re: Need A6351 I.C. for Bestec ATX-300-12Z
Chip is out of production. A couple of options-
1) buy a better newer PSU
2) buy a new 300 on ebay ($25 and up)
3) hope Everell catches this thread and has a spare from one of his "experiments"
4) Ask in the "Wanted" section for either the PSU or the chip. There may be a few hanging about under somebody's workbench...
Always try to give as much info in the thread and first post. A "chip hunter" may get passed-by, but a Bestec PSU hunter may grab more attention.
Welcome to the Forums!
Toast
EDIT: Would you please update your location in your profile. Hate to go digging up something for you only to find you're in Europe and shipping is OMG!Last edited by Toasty; 09-04-2010, 11:24 PM.veritas odium paritComment
Re: Need A6351 I.C.
Welcome to the forum, surfwatcher. It would be helpful to know your location. Are you in the USA, or Europe, or Asia? This is a worldwide forum.
At the moment I don't have a dead Bestec to rob parts from. Once repaired they are (in my opinion) a great power supply and works well.
My suggestion: stop by some computer repair shops and ask for a dead Bestec power supply. The woods are full of them! Most people don't like them - so that is to your advantage. The Bestec ATX-250 12Z and ATX-300 12Z, as well as some of the other ATX-300 models all have that chip.
Bestec puts glue on some of the parts. The glue is yellowish, brownish, or black, depending on how much heat abuse. Get a very small screwdriver and remove ALL of it because it causes shorts and resistive paths between parts (this may be why it failed). AND replace all bulging capacitors.
I am currently working on a "throw away" Bestec ATX-250 12Z. I am modifying it to put active PFC in it. So far I have removed the mains capacitors and replaced them with the new main cap. I have wound and installed the booster coil. And I have installed the large filter cap across the bridge diode. Now I am ready to do some "cut and paste" on the circuit traces. Once I get the "big" parts installed and wired in, I will build a small breadboard for the CS1500 APFC chip. You will find numerous little projects on this forum you can do using a Bestec.Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)Comment
Re: Need A6351 I.C.
Thanks for the input and suggestions. Will take everell's advice and try to pick up an unwanted Bestec from a repair shop.Comment
by acedogblastThis is a guide that I am writing for helping others to replace their MEC1503 EC chip if it breaks (or to get around an inconvenient prompt to the BIOS). This forum has been extremely helpful to me so I would like to contribute to help others. I will tell you right now that this task is very difficult to do. You MUST have experience and tools to do precision micro-soldering, BGA reballing, trace repair, and general laptop repair skills.
There are some specialty tools needed to do this task. The replacement MEC1503 chips can be acquired from Aliexpress. Do not buy the bare chips as... -
by DynaxSCHi
I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6... -
by SMDFleaCommon SPI bios chip programming Questions and Answers
Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
A: If you can`t read from it how do you expect to write to it ?.
Q: Why is my bios chip unreadable ?.
A: The programmer is faulty or has a worn or broken zif socket.
The USB cable is frayed,connector pins worn or some other physical damage.
Not enough amperage or voltage to power the programmer properly.
Bad...-
Channel: BIOS Requests ONLY!
09-02-2021, 04:40 PM -
Long story short:
- dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
- gave the computer to his son a couple years later
- son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
- too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
(seems like the story was not that short)
He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8... -
by TroystainHello, anyone here have updated ezp2023+ chip database in .dat file format.
I need to add w25q256jveq chip but I do not know what data should I type.
I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....11-25-2024, 12:53 AM - Loading...
