Corsair hx620w power on until PG says the opposite
  • Francesc V.
    Tempus fugit
    • Nov 2022
    • 231
    • Catalonia
    Hi:
    I am trying to repair this SMPS, and I see that it powers up (let say for 1-2 secs) and then turns off.
    For this short period I see the 12V,5V,3.3V,5Vstby on........along with the Power Good one. Then PG goes off and then the rest do the same.
    The chip that decides it is a HY510N.
    The voltages that I am reading on the pins are.
    V12 - 11.42V
    V5 - 4.98V
    V3 - 2.57
    PGI - 1.15V
    Any idea what to look at?
    Regards,
    Francesc
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Re: Corsair hx620w power on until PG says the opposite
    Your 3.3V seems to be well out of regulation, so PG should be low.
    PeteS in CA
    • Francesc V.
      Tempus fugit
      • Nov 2022
      • 231
      • Catalonia
      Starting to check the 3.3V rail, then. :-)
      • Francesc V.
        Tempus fugit
        • Nov 2022
        • 231
        • Catalonia
        Well.......getting crazy these days to troubleshoot the issue.......when indeed there was no issue.
        This bloddy SMPS requires from LOAD......otherwise it stops.
        So SMPS recovered from the junk box.
        Regards,
        Francesc.
        • PeteS in CA
          • Aug 2005
          • 3581
          Some power supplies need to be loaded for all outputs to be in regulation.
          PeteS in CA
          • Francesc V.
            Tempus fugit
            • Nov 2022
            • 231
            • Catalonia
            Thank you PeteS. Happy to have learnt something new from this experience :-)
            Regards,
            Francesc.
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • GLISIT
              by GLISIT
              01-16-2025, 02:29 PM
              by sam_sam_sam
              03-31-2024, 02:12 PM
              09-06-2024, 05:59 AM
