Old Compaq Armada internal PSU repair
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    #61
    Re: Old Compaq Armada internal PSU repair
    Leave the primary capacitor alone. Measure voltage on startup capacitor that you replaced. If (whatever voltage) but consistent, you have a dead PWM controller on the primary. Since that PS is so old it is likely a jellybean part, see what the numbers are on it. Replace it.
    If (whatever voltage) but pulsing, it could be either the controller or the resistor feeding the startup cap. More commonly the resistor in this situation. See the numbers or color bands on the resistor, take 1 leg out of resistor (make sure to discharge that big capacitor again before you do that!), measure resistor - if higher value replace resistor. If correct replace PWM controller. Should run then.
    A working TV? How boring!
    • yuuki47
      • May 2021
      • 56
      #62
      Yeah I'm guessing the PWM controller is inside those black-coated PCBs, in which case, I'd have no idea what chip to replace it with. If its the PWM controller, I'm guessing its impossible to revive that PSU.
      I'll do those measurements today and tell ya, have to re-assemble the PSU though.
      • yuuki47
        • May 2021
        • 56
        #63
        Huh, you were right! The voltage in the startup cap stays at a constant 11.3 volts. But that also seems low. It's a 32v capacitor, why would they use something this high for 11k volts?
        But I also noticed that upon disconnecting the PSU from the wall, that voltage starts to fluctuate between 11.3 volts and 9 volts before it settles at 9 volts.
        Weird... I'll have to look for that resistor you talked about.
        It looks like this PSU is toast though if the PWM controller is dead. I don't think those black-coated PCBs are repairable, unless I can remove that black paint somehow?
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          #64
          11.3 is too low. The PWM controllers these use start up at about 13-15 volts. Either the controller is dead, or there's not enough current feeding it. I suspect the former.
          Worth a check. And yes, that black paint is removable somehow, either chemically, by heat, mechanically (scraping/sanding) or a combination of the three methods. But if I were you I'd do something easier.
          I'd take a perfboard and wire in a UC3842 in a basic configuration. Or wait, make it a UC3843, that one starts up at 8.3 volts. Go download the datasheet and it is not important to understand the circuit, just the connections, which part goes where and the inputs and outputs to and from the rest of the power supply.
          Lift the gate pin of the power MOSFET and the two primary side pins of the optoisolator off the board and also connect these to your board. The source pin and current limiting does not really matter for now - use the series lightbulb trick for testing as this power supply does not have PFC.
          See if you can get any output this way. You should. If it works, we can elaborate about making it permanent with current sense/limiting working and everything.
            • 31214
            if the black is smooth then it's epoxy and you can use heat
            if it's rough then it's cement and i have read that oven cleaner with disolve it - not confirmed that though.
            • yuuki47
              • May 2021
              • 56
              #66
              So you're saying that I should get a UC3843 and wire it up in a prototype board with the basic configuration the datasheet has. Ok, I can do that, I've made prototype boards before for a Raspberry Pi Modem Project.
              But uh, this is the part I don't get quite understand:
              "Lift the gate pin of the power MOSFET and the two primary side pins of the optoisolator off the board and also connect these to your board. The source pin and current limiting does not really matter for now - use the series lightbulb trick for testing as this power supply does not have PFC."
              Where is the optoisolator? What even is that? You'll have to excuse me... I'm completely self-taught and a total amatuer, this is just a hobby for me so I'm not well-versed. I would really appreciate it if you could explain this in a bit more detail.
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                #67
                Little 4 pin rectangular black box the size of half a DIP package bridging primary and secondary, also called an optocoupler. Most common one is the EL817, if you see 817 anywhere that is it. Although a power brick that old may have different optos maybe in white DIP packages, some are 6 or 8 pins.
                AT and ATX power supplies with bipolar transistors use current drive transformers, the EE-19 ones in the middle between the 5VSB transformer and the main transformer are what drive the bridge and also provide current monitoring and limiting. Your power brick, although old, should be a flyback topology using an opto so go look for it.
                  • 31214
                  optoisolator looks like a 4pin chip - it's on the edge next to a big diode
                  • yuuki47
                    • May 2021
                    • 56
                    #69
                    Well, okay, I'll have to order more parts. I'll post back when I get around to building the PWM prototype.
                      HP Compaq Compaq SG3-240ES Compaq SG3 220 Specification for Upgrade or Repair
                      This specification for the HP Compaq Compaq SG3-240ES can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-240ES boardview and Compaq Compaq SG3-240ES schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-12-2024, 03:44 PM
                      HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) Compaq Elite 8000 E5500 Specification for Upgrade or Repair
                      This specification for the HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) boardview and Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request...
                      HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower Compaq Pro 6005 B59 Specification for Upgrade or Repair
                      This specification for the HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower boardview and Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                      09-12-2024, 03:36 PM
                      HP Compaq Compaq SG3-331IT Compaq SG3 245 Specification for Upgrade or Repair
                      This specification for the HP Compaq Compaq SG3-331IT can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-331IT boardview and Compaq Compaq SG3-331IT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-12-2024, 03:30 PM
                      HP Compaq Compaq dc7900 Compaq Q9400 Specification for Upgrade or Repair
                      This specification for the HP Compaq Compaq dc7900 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq dc7900 boardview and Compaq Compaq dc7900 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
