HP Omen 15-ek0049, DA0G3EMBCD0 Rev:D (Quanta G3EA / G3E?)
HP Omen DA0G3EMBCD0 G3EA Boardview doesn't seem to correspond with the layout of this board, even though it has the same part number. The area was badly burned but I thought there was a small component connected to the ground stub just above the capacitor. Perhaps that's just a test point and there really was no crispy component that came off when I cleaned up the area.
I just received some TPS65295 ICs so I'll install one with nothing attached to the stub and see if it works. I need to mask off the exposed ground plane in that area before replacing the missing tracks (red). I'll update the post to show what I find. Thanks again for your helpfulness.Comment
It that a common fault in this laptops? Have exactly the same burned chip/area. Does i have effect on the ITE8750E and 3.3V rail? 3.3V rail was shorted, the ITE getting hot, when in injected voltage. 3.3V Up again after removing the ITE. But still have to fix the burned 1.2V area.Comment
Hello TheChief79,It that a common fault in this laptops? Have exactly the same burned chip/area. Does i have effect on the ITE8750E and 3.3V rail? 3.3V rail was shorted, the ITE getting hot, when in injected voltage. 3.3V Up again after removing the ITE. But still have to fix the burned 1.2V area.
I don't know if it's a common fault -- this was only the first or second Omen I have worked on. It sounds like your ENE has a short. Fixing that burnt area is a nightmare, BTW, if it has burned off the top layer of the MB like in my case, exposing the ground layer just beneath the surface.Comment
Hello TheChief79,
Hi Larry,
yeah, mine too. Used some UV mask and still waiting for the replacement chips (ITE and TPS). But i wonder, what caused that burning.
What are the values for the big too caps? The right one is completely missing, the left on was blown.
And is there another component? Resistor or something? Or another small cap?
Maybe 3x 10uF and and 1x0.1uF caps accouring to the datasheet?
that chip is 51393P. closest datasheet is https://www.alldatasheet.com/datashe...TPS51396A.html
did yours burn out? i am suffering the same burnout as other posters in this thread (TPS51486, and most specifically the small capacitor just below it); and indeed under a thermal camera this 51393P chip does in fact get warm, but in my experience when these chips show warmth it is because of a short somewhere else and rarely in these chips themselves.Comment
Hm, cant be an 51393p. The chip on the board has only 16 pins, 51393 has 20 pins. Do u have a detailed picture of that area?Comment
sorry, was looking at it's southern neighbour marked 51393, the chip in question is marked rNCLA
I find myself at the same spot as Larry, with about 1.4 ohms on HWPG. I'm going to have to run off of instinct/suspicions on this one, and start doing some limited voltage injection to the VRM and looking for *any* displays of heat to the mosfet-drivers under a thermal camera (it could be small and momentarily, if my hunches are correct - and after verifying no voltage leakage to the core, of course) **hunch is formed from prior experience with RTX 20 card repairs.Comment
Good morning guys. I have my Omen laptop (DA0G3EMBCD0) that now gives no signs of life (no LED).
During the night I misplugged a slim usbdrive which had the shield damaged, I guess I caused a short because the laptop turned off and never turned on again.
After taking it apart I noticed with the thermal imaging camera that two ICs on the mainboard reach 100 degrees Celsius. Thanks to the boardview I saw that they are PU8600 and PU8601. I tested the pins of these ICs and found these anomalies compared to the schematic
PU8600
6 (3VS5_LX) - 5 OHM to ground (normal?)
14 (3VS5VOUT) - SHORT TO GND
17 (+3VPCU) - SHORT TO GND
19 (3VS5_LX) - 5 OHM to ground (normal?)
PU8601
6 (5VS5_LX) - GND
19 GND - SHORT TO GND
20 GND - SHORT TO GND
Suggestions on how to proceed?Comment
here is boardview
Attached FilesComment
This specification for the HP OMEN OMEN by Desktop PC - 870-118na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-118na boardview and OMEN OMEN by Desktop PC - 870-118na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...09-12-2024, 03:44 PM
This specification for the HP OMEN OMEN by Desktop PC - 870-117na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-117na boardview and OMEN OMEN by Desktop PC - 870-117na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...09-12-2024, 03:44 PM
This specification for the HP OMEN OMEN by Desktop PC - 870-240na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-240na boardview and OMEN OMEN by Desktop PC - 870-240na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...09-12-2024, 03:44 PM
This specification for the HP OMEN OMEN by Desktop PC - 870-010na (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-010na (ENERGY STAR) boardview and OMEN OMEN by Desktop PC - 870-010na (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...09-12-2024, 03:44 PM
This specification for the HP OMEN OMEN by Desktop PC - 870-104na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-104na boardview and OMEN OMEN by Desktop PC - 870-104na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...09-12-2024, 03:44 PM
- Loading...
