Asus P2440UQ
  • Bonzas
    • 472
    • Indonesia
    Asus P2440UQ
    Hello, I need Boardview for this Board. Maybe someone here want to share for free
    Code Board : P2440UQ Rev 2.0
  • Rezistor
    • Jun 2021
    • 302
    • USSR
    Re: Asus P2440UQ
    Asus P2440UQ Rev 2.0 BoardView
    • Bonzas
      • 472
      • Indonesia
      Re: Asus P2440UQ
      Thank you sir
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • DynaxSC
        ASUS STRIX Z490-F GAMING - No POST, stubborn board
        by DynaxSC
        I have this very stubborn ASUS mobo on the bench, and I already face the wall with it. It just refuses to POST, although everything seems to be OK.
        The situation looks like this:
        After connecting the board to the power supply on Nuvoton (SLP_S3#, pin 64), the Low signal (50 ohm resistance) appears immediately. PWRNTN# signal goes through Nuvoton to the chipset (confirmed after removing the chipset). The following conditions are then met for the chipset to generate the SLP_S3# signal:
        1. RTC oscillates normally (32.768KHz).
        07-08-2022, 05:45 AM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • jimbodriver
        Faulty ASUS X99-PRO board. Some progress with repair. Need advice\help please.
        by jimbodriver
        I am trying to learn electronics repair. I purchased a “faulty for spares/repairs” ASUS X99-PRO/ USB 3.1 motherboard for a very low price from ebay – a good enough price to offset the high probability that the board was completely toast and not realistically repairable.
        Initial results:
        Board would power-cycle when turned on either with switch on board or shorting pwr pins. Fan would spin for a second or so and a QCODE of 00 would display then it would power off and then do the same thing again over and over. I think maybe 2 times in about 100 attempts...
        03-20-2022, 02:30 PM
