Hp Stream with charging issue DAY0HGMB6C1 REV:C
  • manuel.it.solution
    • May 2020
    • 30
    • Ghana
    Please I urgently need help with this hp Stream laptop a customer brought to me,when you plug in the charger the power jack led turns red indicating that the laptop is charging but when you put the mouse pointer on the battery it indicates plug in not charging.
    Can someone help me with schematic
    Mobo number
    DAY0HGMB6C1 REV:C
    Tnx in advance
  • mon2
    • 14662
    Re: Hp Stream with charging issue
    I do not see the schematic in my database which is fairly exhaustive. The schematic may not be public yet.
    Post clear pics of the battery charger IC along with the topside markings of the IC.
    Then we can locate the datasheet or a reference schematic to get started of your review. Often, HP will use the TI charger IC and some of these datasheets are posted on their website.
    For this case, continue to post the details in the laptop repair forum.
    • Simone Vergani
      Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
      by Simone Vergani
      I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
      To assist with troubleshooting, I'm attaching two power circuit schematics:
      • Power
      03-05-2025, 02:25 PM
    • drlarsen
      MacBook Air M1 A2337 battery/charging issue
      by drlarsen
      Hello. Sorry for the long post, but I am trying to decide if this is a simple battery replacement, or potentially something more complicated.
      I bought an open box MacBook Air M1 2020 A2337. Seller claimed it was never used. Visually, it appears pristine.
      On arrival, the battery was completely flat. Computer powers up and boots fine. Battery status showing 1% and charging, 1 cycle. coconutBattery showing 0 mAh and ~6 watts.
      After some hours, the battery status did not improve. Restore via DFU did not help.
      I connected the power adapter to a Kill-a-Watt...
      07-17-2025, 02:35 PM
    • ahmarzo
      la-j081p charging issue
      by ahmarzo
      Have Dell la-j081p laptop with battery issue.
      First the laptop was not charging pqb25 was short after changing pqb25 and pqb26 the laptop starts charging and runs properly on charger but battery it shutdown after 10 seconds.
      And when powered on only on battery the laptop turns off after 8-10 second without giving display.have tried another battery on another working laptop and it's working fine
      I have changed charging ic and pqb25 ,pqb26 and pqb13.
      When adapter is disconnected the laptop stays on battery for 8-10 sec then abruptly shutdown everytime.
      This is the link...
      04-24-2025, 05:16 AM
    • DominikPechac
      MacBook Air A1466 820-00165 Charging Issue
      by DominikPechac
      I have a problem identifying a problem on this MacBook Air A1466 with board 820-00165.
      A customer came in with a problem, the laptop was not charging. Otherwise, it works fine - runs from a battery without an issue. The battery is original, the customer also provided his original charger.
      However, when I was diagnosing the issue, I turned the laptop off, checked the board, etc. When I put everything back together, the laptop was charging (I inserted the charger and then turned the laptop on). After unplugging the charger and plugging it back,...
      04-05-2024, 02:20 AM
      HP Stream Stream 14 Pro Notebook PC Notebook 14 Specification for Upgrade or Repair
      This specification for the HP Stream Stream 14 Pro Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Stream 14 Pro Notebook PC boardview and Stream 14 Pro Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
      09-06-2024, 06:40 AM
