ASUS FX506L-FX706L - DABKXDMB8E0-BKXD
  • naseee
    • Nov 2016
    • 104
    • india
    schematic
  • kimsan
    • Nov 2016
    • 6
    • cambodia
    Re: Asus FX506L - DABKXDMB8E0 rev.E - HELP
    • emeron_302112
      • Aug 2021
      • 3
      • philiphines
      hellow to all do you have a boardview for this model FX506L thankyou
      • AL._.EX
        • Dec 2022
        • 896
        • Belarus
        Boardview
        • Shamsi
          • Oct 2015
          • 31
          • india
          Re: ASUS FX506L-FX706L - DABKXDMB8E0-BKXD
          Thank You
          • 230Volt
            • Feb 2022
            • 7
            • Ukraine
            Hi all. Please measure the value of the resistor or tell me its marking in the schematic. In boardview this resistor is not readable
            • AL._.EX
              • Dec 2022
              • 896
              • Belarus
              PR279- 24 kOm.
              • Litwitzk26
                • Aug 2023
                • Deutschland
                Hello
                Can someone please tell me where the fuse for the display lighting is located on the Asus FX506l
                • AL._.EX
                  • Dec 2022
                  • 896
                  • Belarus
                  Fuse F1
                  • dqtech
                    Badcaps
                    • Jul 2018
                    • 640
                    • N/A
                    thanks sir
                    • jboxer
                      • Aug 2023
                      • 10
                      • spain
                      hi can someone tell me what can be if it isn't power consumption there? and what component is? the laptop does not power on and this is the only thing that I have found.
                      • zribit
                        • Aug 2023
                        • 15
                        • France
                        Hello
                        I had a backlight problem after testing this fuse, it entered 20 V and it came out 2 V which was not normal. So I replaced it with a fuse 0603 2A 32V model 0467002.NRHF and the backlight was back.
                        I hope this will help you.
                        Click image for larger version  Name:	f2.jpg Views:	253 Size:	77.3 KB ID:	3173552
                        Click image for larger version  Name:	f1111.jpg Views:	226 Size:	60.5 KB ID:	3173553
                        Click image for larger version  Name:	asus f.jpg bkl.jpg Views:	230 Size:	35.2 KB ID:	3173554
                        • Cire3PC
                          • Jan 2019
                          • 8
                          Can't seem to zoom in close enough with the boardview. What capacitors are here ?
                          • Cire3PC
                            • Jan 2019
                            • 8
                            Do the PDF Boardviews open in some special BV Viewer ? I have Flexboardview and it wont open
                            • deepsky5
                              • Sep 2020
                              • philippines
                              Boardview
                              Hi, Do you have real boardview? .cad file or .fz
                              • M4n0l0307
                                • Nov 2020
                                • 171
                                • Republica Checa
                                Originally posted by naseee
                                schematic
                                Thanks Friend !
                                • kjchatman
                                  • Dec 2012
                                  • 213
                                  • united states
                                  can someone post a close up of the cpu voltage regulator area? i've accidentally moved a few things in that area
                                  • jhzongjhzong87
                                    • Mar 2023
                                    • Philippines
                                    Can someone have the application to view the pdf file as boardview?
                                    • Anirban75
                                      • Sep 2024
                                      • India
                                      I have the same board from ASUS TUF F-15.
                                      1.2v, NVVDD, VCORE , GFX seems short to the gnd. Should I consider my CPU as dead. Surprisingly why NVVDD is short also at the same time? GPU and CPU died side by side?? Any idea?
                                        • 22009
                                        Please start a new thread with your issue in the laptop troubleshooting forum ,this thread is for the schematic request only.
                                        https://www.badcaps.net/forum/troubl...r-s-guidelines
                                        2.2. Don't suspect that something is shorted with no reason
                                        Shorted components are not the only failure mode of a laptop. Additionally, some places will measure low resistance to ground under normal operation. In general, high power low voltage (<2V) power rails will measure less than a few hundred ohms to ground. CPU VCore will measure a few ohms only. GPU VCore with newer NVidia GPU can even measure less than 1 ohm. It's normal. If you suspect a short to ground, always report your exact resistance to ground measurements.
